Canon PowerShot A710 IS Digital Camera Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera says that my sd card is locked and it isn't
My camera says that my sd card is locked and it is not. It was working fine until my grandson started reviewing pictures and zooming in on them. When I tried using the camera after that, I got the message that the memory card is locked. I took the card out and it is not in the locked position. When I put in a new card, it works fine.
Adrian Paun
Level 2:
  • Expert 46 Answers
  • Posted on May 31, 2010
Adrian Paun
Expert
Level 2:
Answers
46
Questions
Helped
17140
Points
118
Try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
1helpful
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Installing SD card in desktop
try using an adapter that you can use to put the sd card in and plug it into the USB drive. The only thing I can come up with is either there is a lock on the sd card, or that slot isn't designed for sd cards but for other cards.
Jul 28, 2012 • Cameras
1helpful
Memory card error - memory card locked when I turn on my camera it has the above error on the screen. The memory card worked fine for a long time before this. I put a new card in and the same thing...
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Vivitar 5399 not reading memory card. Originally had a 4GB card and that worked fine, then all of a sudden the camera wouldn't read the memory card. Card is fine in other cameras. Just switched to a...
Hello
Kind regards
Andrea
Camera says card is locked in the unlocked position. The internal memory works fine.
Hello
Kind regards
Andrea
My SDHC card is locked. When I put the memory card
The problem solved by using the proper SDHC card reader. It is working fine in the camera now.
Dec 29, 2009 • Cameras
I have a kodak m1033, no matter what memory stick it says "card i
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
1helpful
Locked Memory Card
Hello
Kind regards
Andrea
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
