Be sure to check the white separation pad under the second roller - a known wear item. If that is OK, you probably have a sensor switch problem
I am not sure how to get to the feed and seperation rollers/pads in this doc feeder. But if you can access them even a small amount you might try using alcohol solution to clean them up and or a green scott bright scartching pad to ruff the surface up a bit to give them grip and to help clean them off some. might even use a little simple green on the pad to help clean them off thena paper town to dry the rest off. this could buy you some time till you can get a new set of rollers to have put into it
