I have the same problem. My smart finder has never worked. Maybe I'm missing something here. mike vaI have the same problem. My smart finder has never worked. Maybe I'm missing something here.
mike
va
You can't post conmments that contain an email address.
You have a bad power board most likely, replacing it should fix the set, if your quite electronically inclined you could repair it yourself generally for a couple dollars.
Are you sure you have a standing Pilot? You would know if you had to light it. Perhaps you have a hot
surface ignition system, on a call for heat the induced
draft blower will run, then the hot surfave ignitor located on the far right side of burner should glow red
and the burners should light.
Check to make sure the flame rollout switch on the
left side of the burners is not tripped.
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills.
I repair these power supplies, if you need further info write to [email protected]
mike
va
