Hi my samsung 42" rear projection 1080i tv won,t switch on from stand by. it makes a high pitch whistle noise when i press a tv station button on the remote that lasts for about 10 seconds then the standby light starts to flash. help.
DSLReports
Oct 3, 2009 - 30 posts - 7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
TAKE THE AC ADAPTER APART. LOOK AT WHERE THE MANUFACTURER PUT HIS GLUE AND REDO IT CLEAR NIAL POLISH WORKS BETTER IT FLOWS UNDER THE PARTS BETTER. YOU CAN PLUG IT ALL IN WHEN ITS APART BUT MAKE SURE NOTHING CAN SHORT OUT. THIS WAY YOU CAN PINPOINT WHERE THE NOISE IS COMING FROM. OTHERWISE GLUE THE TRANSFORMER AND ANY SMALL FERRITE BEADS THESE SWITCHED MODE POWER SUPPLIES OPERATE AT HIGH FREQUENCIES AND LOOS PARTS CAN VIBRATE CAUSING THIS NOISE.
You Seam to have already found the problem!, If your Wiggling A Cap or Coil and the sound gos away! its the cause of the problem!, replace it, Or A Quick fix is to Use 100% Silicone around problem cap/coil ~ But Let it Dry! before use (24hr) Geo*
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
