Two possibilities can cause the issue .
1. A lose hinge assembly
2. A faulty LCD cable.or the LCD lamp
Try following the instructions given in the following wizard
http://tinyurl.com/6ojva6
In case your system is out of warranty and you need help opening parts , refer to the following
http://tinyurl.com/5w9nsv
Please go through the below step, you can able to do it.
1) Shut down the Dell Latitude D620 if it's currently powered on. Click "Start" in the left-hand corner of the screen to access Windows' shut down options. Alternatively, press and hold the Latitude's power button, located on the top edge of the laptop's keyboard.
2) Turn on the computer by pressing the laptop's power button.
3) Press and hold "F8" on the top of the laptop's keyboard immediately after turning the computer on. If the Windows logo appears on the screen, you're too late and must repeat Steps 1 through 3 again. If you pressed it in time, a list of text options will appear on the screen.
4) Use your keyboard's arrow keys to scroll down to "Repair Your Computer." Push the "Enter" key on your keyboard.
5) Choose a language from the next list and select "Next." If you've password-protected your laptop, you will be prompted to enter your user name and password at this time.
6) Press "Dell Factory Image Restore." A new window will appear. Click "Next" and select the option for reformatting the hard drive and restoring the factory condition of the laptop.
