Tip & How-To about Washing Machines
OK there are a lot of people with the smelly front load washer . the smell is caused buy a build up of detergent it is recommend that you use 2 tbs of detergent and 1 if you have a water softener. also leaving the door open after a washing is good to help it air out . to often people blame the door gasket because they get spots on them well the rubber used is a antimicrobial rubber so it cannot mold . the smell is actually soap build up trapped inside the washer if you run your washer with nothing in it and see soap suds your using to much detergent. there is hope though cutting back on detergent and using a product called Lemeshine mc3 will eliminate the odor issue.
