I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
Hope these info will help you.
Thanks.
hmm, probably grabbed the wrong model number, grabbed it from the X.org log so...
This one had 2 HDMI ports on the back. tried the power-cycle, no luck. haven't seen a factory reset option... (would it be in the diagnostic menu?)
No, please do not perform reset in diagnostic/ service menu unless you have related service manual copy in hand because it will reset many service data that can cause more confusion.
Model number would be written on label pasted at back of tv so let me know it to find out any other way.
Thanks.
ok, no problem.
My bad... it's the 52HMX84... and I fixed the problem... grabbed a copy of the service manual and went into the diagnostics menu... a couple options were out of wack, tweaked them back into line and got both hdmi ports again...
(and discovered that playing with the CWDL value really messes with your colors...
