The washer runs but does not spin...
Below is for Whirlpool/Kenmore, u might find it helpful. Some
machines have a small trap door on left front bottom, coin trap.
The
filter on your pump is probably clogged with lint and stuff. You have
to remove the bottom front panel, 3 torx screws underneath. The
panel will drop and come off. Drain off the excess water
from the drain pipe you see. The white filter cover is right in front.
Get yourself a good plastic bag to collect water. Unscrew the filter
cover and twist the filter out. Clean out all the stuff and put it back
in carefully. Check your pump too, comes after the filter.
On
some models the filter is located ‘inside’ the big hose from the bottom
of the tub. This takes more time to clean.
