Cant figure out how to tighten the belt - Washing Machines
  • 159 Answers
Some front load washers don't have any adjustment at all.the motor is fix in one position.to put a new belt on can be quite difficult,you just have to try & wined the new belt on.it will be very tight.
Posted on Jun 04, 2010
6ya staff
SOURCE:
How do I tighten the belt of a technogym excite 700 treadmill?
Easiest way is to remove the back guard at the back of the belt (dark grey). I think it's #3 allen keys. There are bolts on the side, and potentially underneath.
Once removed, you will see two large bolts that connect to the back roller. Turn those with a #8 allen key (I believe). If it is because the belt is loose, I'd only do 1/4 turn on each side at a time as you don't want to tighten too much or it stretches your belt, and may also cause your lower kit to blow something.
Jun 25, 2014 | True Technogym Excite Run 700 Treadmill
Belts are slipping on my mill and cant figure out how to tighten.
2002 f250 diesel will turn but it wont start. I put starting fuel in it. It almost starts and it just shuts off.
Aug 26, 2013 | Cars & Trucks
How to replace alternator belt
Find the belt tensioner bolt and loosen it. There will probably be two other bolts that need to be loosened (just loosened not removed). Move the alternator to its " most slack position" pull the old belt off anf fit the new one. Push the alternator with a broomstick or something similar to tension the belt. (Be sure to push against a solid part of the alternator or you could break it) tighten the tensioner bolt. the tension should be set so that you can push the belt in about 20mm between the pullies with your finger. If the new belt squeels when you start the car the belt is too loose. Tighten the other two mounting bolts.
LPG
Sep 10, 2012 | 1999 Renault Megane
How to remove belts from 1994 dodge caravan 2.5 liter
Drive Belts
Print
INSPECTION
See Figures 1, 2, 3, 4 and 5
Check the condition and tension of all drive belts every 12,000 miles, or at least once a year. Loose drive belts can lead to poor engine cooling and diminished alternator, power steering pump, air conditioning compressor, or emission air pump output. A belt that is too tight places a strain on the bearings in the driven component.
Fig. Fig. 1: There are typically 3 types of accessory drive belts found on vehicles today
Fig. Fig. 2: An example of a healthy drive belt
Fig. Fig. 3: Deep cracks in this belt will cause flex, building up heat that will eventually lead to belt failure
Fig. Fig. 4: The cover of this belt is worn, exposing the critical reinforcing cords to excessive wear
Fig. Fig. 5: Installing too wide a belt can result in serious belt wear and/or breakage
Replace any drive belt that is glazed, worn, cracked, or stretched to the point where correct adjustment tension is impossible. If two belts are used to drive a component, always replace both belts when replacement is necessary. After installing a new belt, run the engine for ten minutes, shut OFF the engine and recheck the belt tension. Readjust if necessary.
ADJUSTMENT
See Figures 6, 7, 8, 9 and 10
Fig. Fig. 6: Engine belt tension chart-2.2L engines
Fig. Fig. 7: Engine belt tension chart-1987-89 2.5L engines
Fig. Fig. 8: Engine belt tension chart-2.6L engines
Fig. Fig. 9: Engine belt tension chart-1990-93 models
Fig. Fig. 10: Engine belt tension chart-1994-95 models
Two popular methods of checking drive belt adjustment are; the Belt Tension Gauge Method and the Belt Deflection Method. The former requires a special gauge and the latter requires a straight edge and scale or just a good eye for measurement. The deflection method will be used in the following belt replacement instructions. A rule of thumb for checking belt tension by the deflection method is to determine the midpoint between two pulleys of the drive belt and press down at that point with moderate thumb pressure. The belt should deflect to the measurement indicated in the following installation procedures. Adjustment is necessary if the belt is either too loose or too tight.
WARNING A belt adjustment which is either too loose or too tight will eventually damage the accessory that belt is driving. A too loose adjustment allows free-play in the belt which could transfer a whipping motion or shock to the accessory drive pulley. Similarly, a belt which is too tight will preload the accessory bearings, leading to early failure.
REMOVAL & INSTALLATION
See Figure 11
Raise the front of the vehicle, support on jackstands and remove the lower splash shield if access is hampered due to space limitations when changing drive belts.
Fig. Fig. 11: Support the vehicle, then remove the lower right side splash shield for access to the drive belts
2.2L Engines
A/C COMPRESSOR DRIVE BELT
See Figures 12, 13 and 14
Fig. Fig. 12: A/C compressor drive belt adjusting points-2.2L engines
Fig. Fig. 13: Loosening the locking screws for A/C compressor drive belt removal
Fig. Fig. 14: Removing the A/C compressor drive belt from under the vehicle
  1. Loosen the idler pulley bracket pivot screw and the locking screw.
  2. Remove the belt and install a replacement.
  3. Using a breaker bar and socket apply torque to the welded nut provided on the mounted bracket to obtain proper tension.
  4. Tighten the locking screw first, followed by pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR DRIVE BELT (CHRYSLER TYPE)
See Figures 15 and 16
Fig. Fig. 15: Alternator belt adjustment-2.2L engine
Fig. Fig. 16: Loosening the locking screw for alternator drive belt removal
If removal of the alternator belt is required, the A/C belt must first be removed.
  1. Loosen the pivot nut, locking screw, and the adjusting screw.
  3. Adjust to specification by tightening the adjusting screw.
  4. Tighten the locking screw to 25 ft. lbs. (34 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (41 Nm).
ALTERNATOR DRIVE BELT (BOSCH TYPE)
  1. Loosen the pivot nut, locking nut, and adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (34 Nm).
POWER STEERING BELT
If removal of the power steering belt is required, the A/C and alternator belts must first be removed.
  1. Loosen the locking screw, and pivot screw.
  3. Install a 1 / 2 in. breaker bar into the pump bracket slot, apply pressure with the breaker bar and adjust the belt to specification.
  4. Tighten the locking screw first, then the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
AIR PUMP DRIVE BELT
See Figure 17
Fig. Fig. 17: Air pump belt adjustment-2.2L engines
When servicing the air pump, use the square holes provided in the pulley to prevent camshaft rotation.
  1. Remove the nuts and bolts retaining the drive pulley cover.
  2. Remove the locking bolt and pivot bolt from the pump bracket, then remove the pump.
  3. Remove the belt and install a replacement.
  4. Position the pump, then install the locking bolt and pivot bolt finger-tight.
  5. Install a 1 / 2 in. breaker bar into the bracket assembly (block the drive pulley to prevent camshaft rotation), and adjust the belt to specification.
  6. Tighten locking bolt and pivot bolt to 25 ft. lbs. (35 Nm).
2.5L Engines
AIR CONDITIONING COMPRESSOR
See Figure 18
Fig. Fig. 18: Drive belt adjustment points-2.5L engines
  1. Loosen the idler bracket pivot screw and the locking screws to replace, or adjust belt.
  3. Adjust the belt to specification by applying torque to weld nut on the idler bracket.
  4. Tighten locking screw first, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
ALTERNATOR BELT
See Figure 18
If replacement of the alternator belt is required, the A/C drive belt must first be removed.
  3. Adjust the belt to specification by tightening the adjusting screw.
  4. Tighten the locking nut to 25 ft. lbs. (35 Nm).
  5. Tighten the pivot nut to 30 ft. lbs. (40 Nm).
POWER STEERING PUMP
See Figure 18
If replacement of the power steering belt is required, the A/C and alternator belts must first be remove.
  1. Loosen the locking screw and pivot screw to replace, or adjust the belt.
  3. Using a 1 / 2 in. breaker bar positioned in adjusting bracket slot, adjust the belt to specification.
  4. Tighten the locking screw followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
2.6L Engines
ALTERNATOR/AIR CONDITIONING COMPRESSOR BELT
See Figure 19
Fig. Fig. 19: Drive belt adjustment points-2.6L engines
  1. Loosen the locking screw, jam nut, and pivot nut.
  2. Loosen the adjusting screw.
  4. Adjust the belt to specification by tightening the adjusting screw.
  5. Tighten the locking screw followed by the pivot nut. Tighten to 16 ft. lbs. (22 Nm).
  6. Tighten the jam nut to 21 ft. lbs. (28 Nm).
POWER STEERING PUMP BELT
See Figure 19
If replacement of the power steering belt is required, the alternator and A/C belt must first be remove.
  1. Loosen the pivot screw, and the locking screw.
  2. Remove the timing pickup.
  4. Install a 1 / 2 in. breaker bar in the adjusting bracket slot, torque to specification.
  5. Tighten the locking screw, followed by the pivot screw. Tighten to 40 ft. lbs. (55 Nm).
  6. Install the timing pick-up, and tighten to 160 inch lbs. (18 Nm).
Jul 26, 2012 | 1994 Dodge Grand Caravan
Replaced alternator and all components and the belt is too loose. All the components are in the right place and I cant figure it out. I didn't disassemble the motor so I need some expertise in the...
YOUR V BELT HAS A ADJUSTER BOLT LOOSEN ADJUSTER BOLT TURN THE TURN TENSION BOLT UNTIL DRIVE BELT START TIGHTEN YOU SHOULD HAVE ABOUT 1/2 INCH DEFLECTION WHEN YOU PRESS DOWN ON BELT WITH THUMB. DONT TIGHTEN V BELT TOO TIGHT WILL CAUSE WATER PUMP AND ALTERNATOR SHAFT BEARING FAILURE.
Jul 19, 2011 | 1996 Volvo 850
I have a 94 eclipse and my alternator belt snapped i took all the belts off they pulleys to get to it and i put the new alternator belt on and it is really loose and i cant figure out how to get it...
Make sure you have the belt routed correctly. There should be a diagram under the hood of how to do this. If it is correct then the part store may have given you the wrong belt. I have had this happen many times. It is annoying but it does happen. I hope this helps.
Oct 05, 2010 | 1994 Mitsubishi Eclipse
I cant figure out how to move belt tensioner on ford escortz2x to allow play to put belt back on
Use a 13 mm wrench to turn the bolt on the tensioner clockwise, like you are trying to tighten the bolt. The arm should swing towards the rear of the car. If it does not, then the tensioner is bad and should be replaced.
Mar 13, 2010 | 2001 Ford Escort ZX2
Belt broke that drives the water pump and alternator on my 88 plymouth reliant. another belt in the way, and cant figure out how to get the new belt on.
You can loosen the alternator that should releive the tension on the belt.
When you tighten it again make sure you can only turn the belt 90 degrees then you know you have the right tension.
Jul 11, 2009 | 1988 Plymouth Reliant
Alternator belt fell off
You may have to buy a new belt because that one may have stretches. After you buy a new belt. Look at he alternator, it has two screws, one hold it in place and the other allow it ti move. Lose both a little. With a pry bar push the alternator so the belt can fit. Look for the belt routing diagram in the engine compartment. Follow it and put the belt on. You were suppose to have a belt tension tool to determine the tension. Then use your pry bar to move the alternator to position and tension then tightened alternator screws.
Mar 13, 2009 | 1998 Mazda 626
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
