Question about Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b
Reset to default a symbol spectrum24 ap-3021
I need to know how to reset to default and then configure a symbol spectrum24 model ap-3021-500-us access point
  • 2 more comments
  • gaoloogo Aug 13, 2008
    Need torest my dynex router key
  • slunce May 11, 2010
    Hello all,
    Do you know how to backup the configuration for the
    Symbol Spectrum24 APs? What I would like to do is create a backup( from web or telnet) of
    the configuration and be able to restore it to another Symbol AP. There
    is however ways to restore the configuration from the web interface. Am
    I missing something here??
  • Raj Thapa May 11, 2010
    hi sir,
    how r u today? i have one question, how to reset engenius eoc-3220.
  • Haywood Alex
    Haywood Alex Dec 15, 2019
    MikroTik manufactures routers, switches and wireless systems for every purpose, from small offices or private households to carrier ISP networks. There is a device for every purpose. In our product catalog you will find a complete list of our products and their functions. MikroTik Academies are educational institutions such as universities, technical schools, colleges, vocational schools and other educational institutions that offer their academic students semester-based internet networking courses with MikroTik RouterOS as a learning tool.https://hdlicense.com/mikrotik-keygen-fu...
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Posted on Sep 17, 2008
  • miguel mata
    miguel mata Nov 02, 2013
    gracias logre recetear pero quiero cambiar clave pero no recuerdo la clave y simbolo no funciona
  • miguel mata
    queria saber cual es la IP de spectrum24 LA 4121 para cambiar la clave y nombre de red
ALL GOOD
Posted on Oct 30, 2008
Cool. It works. But what is the default ip? I can't search it....please help.
Posted on Aug 25, 2009
Looser
Posted on May 05, 2008
  • 85 Answers
Check the bottom back of the AP you should see a reset button or a tiny hole indicating reset, press and hold it down for 4-6 seconds then try to use your browser to log into the refresh access point.(use default ip address to login from your browser
Posted on Apr 23, 2008
6ya staff
SOURCE:
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
Hi! I have a number of SPECTRUM24 4131 acces points. I would like tu use them for commercial purpose in a hotel in africa with a web portal for login authentification. I am looking for a skilled person...
What do you need to know / what do you already know ? This is a large question.
1. Are all your access points configured
2. For your captive portal you could use MikroTik software. There is a large community based on the software and step by step instructions to setup a captive portal.
Mar 01, 2011 | Symbol Spectrum24 4131 Access Point...
I want to bridge two AP's but they don't find each other.
the issue is if your using bridge mode then you have to use differnt IP for both Router
if your main router using this IP like 192.168.1.1
second router sute use folowing IP 192.168.2.1
it will work changing IP's
Apr 20, 2010 | Symbol Spectrum24 4131 Access Point...
When we tring to ping for a work station the IP address is on time out?
timeout most likely means that you hit firewall on you way in ( there is router online
Jul 10, 2009 | Symbol Spectrum24 AP 3021
My symbol 4131 and pdt4686 won't associate. Please help.
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual:
http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
Jul 01, 2009 | Symbol Spectrum24 4131 Access Point...
I need user manual of Symbol Spectrum24 4131 Access Point 802.11b
Hello minhaj,
You can download the structure manual of Sympol Spectrum 24 4131 by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | Symbol Spectrum24 4131 Access Point...
Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Logo
13,037 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
