Question about LG 37LC7D 37 in. LCD HDTV
HEY DAWNN,I HAVE THE MOD.# AND SERIAL# FOR MY LG 37LC7D FLAT TV POSTED,THANKS.
My LG flat panel tv mod# is:37lc7d-ub and product code#:37lc7d-ub.ausvlmm
SERIAL# IS:707mxjx0e996.
thanks man and help me,you can also tell me if i can repair this power supply board by changing parts you tell me or if i need to buy the whole board tell me the best solution,thanks again,FARADIO FROM PLANO,TEXAS.
  • LG Master
  • 2,800 Answers
Just change the board unless its just a fuse that is blown
Posted on Nov 15, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Buying 37 inch LG TV
no, horrible tv - if your going to buy it, get a warranty
Posted on Jan 20, 2008
ALL_TECH
SOURCE: hi shawnn,i'd like to know the if it's only power supply faulty and i need the board #?thanks man.
have the same problem and already replace ps from fleabay and still dead , looks llike the problems is on the main board.
Posted on Jun 10, 2008
Anonymous
SOURCE: LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
Posted on Nov 09, 2008
Anonymous
SOURCE: how to connect speakers to LCD
there is a sound or speaker out jack on the back of the tv, this must be sent to a reciever of some sorts. any older home sound system will do. use the audio in jacks or aux. jack and your on your way!!! its not that hard !!! just take your time and it will be so easy!!!!!!
Posted on Feb 03, 2009
premtech
William Rayburn
  • 934 Answers
SOURCE: LG 37LC7D
Howard,
Do not keep forcing this unit on - - This particular unit has a VERY commonly known problem and there are at least five tech bulletins from LG explaining this and other symptoms for the failure. In a nutshell there are coils that have to be removed and replaced with a jumper wire. This is not a repair you want to tackle so please get some experienced help for this one. A good technician will look-up the bulletins and educate themselves on the manner of the repair.
Almost all of the symptoms that can happen are intermittent and can be extremely difficult to verify. For this reason make sure to discuss with the technician that he replace all of the coils listed in the bulletin not just the ones causing your particular problem. Here's a list of symptoms that these defective coils cause, taken right from the bulletin:
1. Channels Or Menu Functions Scroll On Their Own
2. Remote Does Not Function
3. Tv Randomly Powers On And Off On Its Own
4. Dead
5. No Backlight
Hope this helps!
William Rayburn, CET
Premium Technologies
Posted on Aug 03, 2009
I have a LG 37LC7D-UB tv. Trying to find part # 37LC7D-UB.AUSTLJM or Cap Kit for such. But when I find the part, say on EBay or other supply houses the board # is not the same. any tips on making sure
Ask eBay sellers to send you pictures and compare those to the original component, alternatively send eBay sellers pictures of your part and see if they can confirm they have the replacement for it.
If you want to change the caps, they should all be stamped with their ratings, you could order them individually from electronics suppliers. Just make sure you order the same ones in replacement, including ensuring the replacements are the same diameter. The last thing you want is to order a load of caps that don't fit around each other.
Mar 18, 2014 | LG 37LC7D 37 in. LCD HDTV
No sound on lg 37lc7d 37 in lcd hdtv
Apparently something else has failed on the circuit board(s).
Nov 10, 2013 | LG 37LC7D 37 in. LCD HDTV
No sound on an lg 37lc7d tv?
Your main pcb could still have gotten damaged due to the defective caps. The reason you still have audio through the optical is because it is a digital signal only. It is not running through the audio amplifier on the main board. I would suspect either the main pcb or the speakers them self.
Mar 15, 2013 | LG 37LC7D 37 in. LCD HDTV
Looking for a tv stand for LG 37LC7D 37 in.
I would suggest you check ebay, or shopjimmy.com.. there was one at shopjimmy.com but I am not sure if it is still available.
good luck!
Aug 25, 2010 | LG 37LC7D 37 in. LCD HDTV
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
May 20, 2008 | Televison & Video
yes this is a good unit i have one
Nov 17, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 37LC7D 37 in. LCD HDTV Logo
103 people viewed this question
Ekse
RONALD CARTER JR
