Question about Nokia 5130 Cellular Phone
My nokia 5130 suddenly hang while operating & now there is only white screen, please help me
    New Friend:
Nokia 5130 c_2 hang (white nokia simbail)
Posted on Sep 20, 2010
    President:
  • 2,047 Answers
Try removing the battery for 5 seconds and putting it back after...
Posted on Jun 05, 2010
    New Friend:
Hai sir my phone will restart white screen tell the solution of the problem
Posted on Jun 23, 2011
    New Friend:
When i on my nokia 5130 phone it opens but it hangs with a white screen...why i want the answr...? Plzz help me...
Posted on Jul 26, 2013
    Master:
  • Nokia Master
  • 233 Answers
Why not try to use an applock to boost your phone, boost feature will very useful for your situation. LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Dec 23, 2016
6ya staff
SOURCE:
Hangs in opening gallery
Try to restart your phone.
Oct 13, 2012 | Nokia 5130 Cellular Phone
I have nokia 5130 xprees music. i saw this problem many time. screen is white and phone is unable to on. when i goes to on phone white screen appers and some time it off or some time no more process i
Frequently nokia 5130c damage / corrupt it's operating system.To fix this you need to flash the phone, if you want to do it by yourself Click here1.And here is your 5130 flash file.During selection of Product code choose this 0579014: RM-495 CTR SEAP MS SILVE BENGALI BANGALA.Good luck
Feb 22, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
My set suddenly hanged switch on it light hanged. nothing works switches.
I think that some virus might infected to your phone so you need to flash/update.Just follow the procedure below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/Click here1. thanks for visiting fixya. Good luck.
Aug 29, 2011 | Nokia 5130 Cellular Phone
When i try to open my nokia 5130 .. it will open .. but when i open it will hang , :( pls help me
it is a software problem to Solve it Please Visit your nearest Nokia Service Center (Nokia Care) they will renew your mobile Software.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jun 21, 2011 | Nokia 5130 Cellular Phone
My nokia 5130xm having hanging problem on startup
Try factory resetting the phone .
This can be done through Setting - Factory reset .
Please save all the data .
IF this doesnt helps , try updating the software version of the phone by goint o setting - update firmversion . But this may result in losing your Operating system of the phone . So try only with
Nokia Software Updater .
Or if the Phone hangs on a very frequesnt basis try giving it to NOkia service center .
May 27, 2011 | Nokia 5130 Cellular Phone
I am using nokia5130 mobile... my mobile is often getting white screen while i was using it... how could i over come this problem?
I have nokia 5130 Xpress music C2 phone and 2 hours ago my phone goes to a white screen and suddenly changes to normal mode and process goes on repeating!!!!.The process repeats for a fixed period of time ???please give me a good suggestion to solve this problem if u know it!!!!!!!
Dec 14, 2010 | Nokia 5130 Cellular Phone
My Nokia 6233 Hangs & Then Shuts Down.
check the side button PTT
and make full reset
May 11, 2010 | Nokia 6233 Cellular Phone
Nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Mar 26, 2010 | Nokia 5130 Cellular Phone
Nokia 5130 Cellular Phone Logo
1,292 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
