My 13 or14 year old Kitchenaid washing machine is getting hung on a cycle and running for hours like that. It does it on the heavy, regular and perm press setting but not the delicate (yet!) and of course overheats from running so long. It has hung up on the "drain the water cycle" and the "spin cycle". We've never had many repairs and wondered if this is something we can repair ourselves or is the machine too old for parts to still be available? Model # KAWE677BWHI
SOURCE: KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
SOURCE: Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
you need to replace the lid switch
SOURCE: whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
