How to set up for voip phone line
Getting a new VoIP number is not hard!
Here's how to get a VoIP line easily (Step by Step!):
1. Go to Global Call Forwarding ( https://www.globalcallforwarding... )
2. Select your new phone number country, city, and select the number. Then enter your destination number.
3. You can hit "Try for Free" to get a free trial, but you will have to enter your contact information first before you can view the rates. If you don't care about the free trial, just hit "Skip Free Trial - View Rates" in order to view all of the rates instantly. You can always change this later.
4. Select a plan you would like to try for free
5. Select optional features for your toll free number.
6. Hit the try for free button to go to the shopping cart
7. In the shopping cart, look over your order information. You also have the option to add additional numbers, and turn free trial on or off
8. Now just complete the checkout, and you're good to go!
I hope this helps!
My brother used the services of this company SendMyCall https://www.sendmycall.com/ and was satisfied. There are instructions on how to configure everything. https://www.sendmycall.com/support
There are quite a few instructions for VoIP devices on Zadarma http://www.zadarma.com/. If it is not there, you can check out different software they offer for their virtual numbers and free cloud PBX.
Using a virtual phone number you can operate with the virtual phone line to communicate over the internet.
Get New York Virtual Phone Number 6 Instantly CallHippo
If your VOIP adapter has only one service line (VOIP PIN configured) then you have to remove the phone line and connect the FAX line. Now if you have the two service lines (in the both port separate VOIP PIN should be configured) - then you may connect this FAX to the other port. Both (Phone as well ad FAX) will work simultaneously. (Remember - two seperate PINS are required if you attach phone as well as FAX line in same adapter). After attaching the FAX - every think is normal like normal FAX line. Generally you don't have to dial pre country code like 011 or 00 or +, just dial the number starting from Country code.
FAX was designed for analog networks, and does not travel well over a VOIP network. So I recommend you using VOip Gateway and an ATA that supports T38. For getting better result please disable the Error Correction mode on your fax machines.
It won't work
