Samsung S850 Digital Camera Logo
Posted on Jun 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix the card error or card lock - Samsung S850 Digital Camera
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Jun 06, 2010
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607436
Points
3590
Check the write protect tab on the on the side of the card ,slide it to remove the lock.hope this helps
Problem with SD card; says card "locked" or memory card error.
Take out the SD card. Look on the side of the card for the slide switch. Make sure that it is in the unlocked position. The switch is on the left side (without the notch). The locked position puts the switch further from the pins on the end of the card that is inserted into the device. On some cards, as the card ages, the switch can slide just from the force of inserting the card in the slot. If the lock switch is in the unlocked position or it's locking just in handling, replace the card. The memory or the card has probably been damaged.
In some cases, you can force the broken switch to stay in the unlocked position with some glue/tape. Use tweezers to move the switch to the desired position. (However, you need to ensure that you don't break the card in handling and that the fix doesn't make the card too thick to fit into the card reader/slot.) This switch is similar to the lock switch on old 3.5" floppies. The fix is like fixing cassette tapes or 5 1/4" floppies that were made read only.
I hope this helps.
Aug 23, 2021 • Cameras
My camera Canon sd 940 shows an error memory card error and card lock, how to fix it?
Have you tried unlocking the card with the small slider switch on the side of the card
Lexar sd card error, it is a 16gb Lexar sd card. When I put the card in my camera it says "card error-card is locked. Need to know how to fix this card.
SD cards have a slide switch along one edge.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
2helpful
Card locked error
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How to fix memory card error problem and card locked ,fix is in the camera.
Is it physically stuck in the camera or there is a message stating that the card is locked?
A locked SD card can be unlocked by sliding the tab on the long edge to the opposite (unlocked) position as shown below:
1helpful
Card error
the problem could be multiple things:
1. it's switched into card mode... without a cord 2. the card is locked, this can be fixed by retrieving the card from the camera, then pushing the lock switch down away from the word "lock" (the opposite direction of the tiny little arrow) 3. THe card is corrupted, for this there really is no fix, sorry.
hope this helped- snowsurfer58
Error: This card can not be used
Greetings Qstorm92,
My guess is that the card is locked. There is a small lock on the side of the card that can sometimes accidentally slide to the lock position. Try checking this and see if this fixes your problem.
Thank you,
Dorothy
Go Ahead. Use Us.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
