Hey I went to properties and I have full control but i still cant save it it says cannot create the file make sure that the path and file name are correct . what do i do?
Hello SONALI
Make HP laptop webcam work in Vista
Here's the information for finding and properly downloading
the correct drivers and software updates that will make your HP web camera work under Vista.
First do the following:
1. Have an internet connection
2. Have your correct model number ready
Then do the following:
1. Select your Pavillion laptop model from this list
2. Click on the "software & drivers" link
3. Select your operating system
4. Scroll to the bottom and download the software update file
5. Follow the instructions on that page
What else you should know about making the HP Pavillion webcam work with Vista
HP will be periodically releasing drivers and software for the
built-in webcam for users that have the pre-installed version of Vista
on their Pavillion notebook. If your the type of computer user that has
a habit for trying out new software, devices and basically anthing for
a computer then you'd better get used to spending more time getting
those things to work with Vista for awhile.
I hope this page of information helped you find out how to make your HP pavillion laptop webcam work with Vista..
AND Pls tell what kind of error u are getting while connection CAM to Internet
I hv purchsed HP Pavilion tx1000 notebook pc. it was getinig vy heat due to this region pc was getting shut down. i hv given it to my near by service center. but still it is not working properly. its web cam as (HP pavilion Webcam Driver for Vista v061.001.0005- chicony) driver is also not loaded properly. when opens with net it gives error.
pls help me wht to do?
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
this may vary depending on your operating system
Hope this helps.
Click permissions
if you need more help with this post a reply
hop this helps
Click permissions
hope it helps
Click permissions
hope it helps
Are the files write protected or just your usb drive
right click on the file select properties security make sure you have full control
Click permissions
hope it helps
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
Click permissions
hope it helps
click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
Right click the icon of your Usb Drive (It should be E:/ or something)
Click permissions
hope this helps you
click start click to open on my computer you should see your transcend usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
Click permissions
hope this helps you
pls help me to what is the best solution to connect my web cam
