My whirl pool washing machine 1400 has stopped working the 'service' light is lit up. how do i get rid of the service light and get it working again?
My whirl pool 1400 will not drain the water wat could be wrong it is not blocket and it makes a terible noise please enny one out there i need help
Them washer are what you call high efficiency washers.HE. They only use 1 gallon of water to wash them clothes. You go adding more than a teaspoon of soap and that washer is gonna have a cow. Over a period of time that soap gonna build up so much the washer is gonna just give-up the ghost. If you know you use the correct amount of soap there could be something in them pump.You need to remove the service panemy whirl pool 1400 has stopped working the - 41b08ad.jpg/uploads/images/41b08ad.jpg" alt="41b08ad.jpg" class="h_mi" /> and take a looksee at that tech sheet and see what it say about them light flashing. Wmy whirl pool 1400 has stopped working the - 6349b09.jpg it you may as well remove that cap and clean out that filter. That might put yall back in business. That tech sheet will be in there bymy whirl pool 1400 has stopped working the - 539a7ad.jpg box which is the motor control unit. The other stuff that the tech sheet error chart might reveal is located on the topside. Good luck on dat repair mon ami.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
