Roper RT21AKXKQ Top Freezer Refrigerator Logo
Posted on Jan 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker quit working
It appears that the water is not getting to the ice maker. Water is getting the "part" at the bottom of the refrigerator but does not seem to be moving up. My refrig model is RT18AKXKQ and the part # that I am referring to is "model 70, MOPD 150 psi, 2210436. Any suggestions are appreciated. Thanks
vince
Level 3:
  • Roper Master 2,530 Answers
  • Posted on Jan 08, 2018
 vince
Roper Master
Level 3:
Answers
2530
Questions
0
Helped
748022
Points
8845
5 Related Answers
applianceboy
Todd Marr
  • 77 Answers
  • Posted on Sep 26, 2007
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Anonymous
  • 473 Answers
  • Posted on Oct 18, 2007
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Anonymous
  • 1142 Answers
  • Posted on Mar 24, 2009
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • christian nielsen
    • 358 Answers
    • Posted on Apr 26, 2009
    SOURCE: the ice maker on our GE refrigerator does not make ice
    1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
    bobicehouse
    Robert Moller
    • 1524 Answers
    • Posted on Apr 27, 2009
    SOURCE: Roper Ice maker wont kick ice cubes out of tray.
    Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
    GE bottom freezer ice maker not working
    Remember there are two sides to a dual water control valve, the water to dispenser side and the side that feeds the ice maker. Replace the WR57X10094 Dual Water Control Valve and I think you will be good to go on ice, Thanks Sea Breeze
    Ice maker not working
    OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
    Ice maker quit making ice
    There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
    1helpful
    No ice
    IPour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
    2answers
    Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
    There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
    1helpful
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    5helpful
    My Jenn Air refrigerator ice maker quit working
    My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
    ice maker?
    [email protected]
    1helpful
    Ice maker
    I am having the same problem with mine.
    Top Roper Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
