Kyocera FS-1118MFP Laser Printer Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code error 1102
There are problem in scan copy send to email id not complete ..thier are code error 1102 show.
Anonymous
Level 2:
  • Expert 241 Answers
  • Posted on Jun 09, 2010
Anonymous
Expert
Level 2:
Answers
241
Questions
Helped
159359
Points
801
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
What does it mean when I receive error code 1102?
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
1helpful
How to solve scanner error 12 problem
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for observation, its easily available in leading spares vendors in India.SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
2helpful
2answers
Hi Am having kyocera 4050 b&w Copier i have problem with my scan its showing the error code is 1102 can u help me
Here is what an 1102 error is and what some of the things to look for are.. hope it helps..
1102 SMB(SMB)
Error: User/Password or SharedName/FolderNameDomain name not entered as Domain UserInput
User Name with one of the form "Domain\User", "Domain/User", "User@Domain"SMB)
User Name/Password or Shared Name/Folder Name ErrorSpecify invalid User/Password (includes unspecified)Input correct User Name/PasswordSpecify the User who is not permitted for accessing to the folderInput correct User and Password
Check access limit for send destination folderSpecify invalid Shared NameInput correct Shared Name
(See the reference for the symbol which is possible to use for Shared Name)Host Name ErrorCheck if any prohibited letter (see the reference) for Host Name is included or notSCAN TO EMAIL(SCAN TO EMAIL)
User Name/Password ErrorUser ID for Authentication is not entered/entered wrong User ID
Wrong Password for Authentication is enteredInput User ID/Password which is used for Authentication from [Advanced] on Command Center correctly
([Login User Name] on [POP3] page or [SMTP] page)
It's actually related with SMB.
The shared folder on the server may be blocked by an open ghost connection.
A restart of the samba service may repair
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Hello my nokia 3110 mobile got hang and switched
my nokia 3110 mobile got hang and switched off automatically. to restore factory setting i put the code 12345 or 00000 but i shows code error. i think there is virus in my mobile. now i dont know the exact code to format my mobile. pls send me the procedure to format my my and give me the right code to format it. follwing is the information of nokia3110c: Email Id :- [email protected]
2helpful
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
1helpful
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
4helpful
2answers
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
