Not sure what happened with your device. If the problem keeps occur, you can try a 3rd party iPod music transfer program on your computer. How to Transfer Music to iPod without iTunes
Disconnect iPod shuffle from the computer (if connected).
Move the switch on the iPod shuffle to the OFF position. Note that when iPod shuffle is off, the green stripe by the switch is not visible.
1st generation
2nd generation
3rd generation
4th generation
Wait five seconds. For iPod shuffle (3rd and 4th generation), wait ten seconds.
Move the switch to the play in order or the shuffle position. The green stripe will be visible in either position. For iPod shuffle (2nd and 4th generation), slide the power switch on (and you can see the green stripe).
you have to use ipod reset utility.you can download it here..
http://support.apple.com/kb/ht1238
install it and just follow on screen instruction. after the process is completed, sync your shuffle to itunes. after that your ipod shuffle would work as normal. my concern is, dont ever try formatting again using format utility of windows, you might get the shuffle corrupted permanently.
You did not say if you have a shuffle,nano,mini,etc.
The only thing I can do is send you to the page that has them all and you will have to pick the right on.
Good Luck, I hope this helps
Please rate me
Go to the following website for you user manual download:
http://support.apple.com/manuals/#ipod
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
• If you choose to update, the software is updated, but your settings and songs are not
affected.
• If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
i have one and it will charge the light means it is charging just leave it on until done and the light goes off you should see it on the lower right side by the clock on your computer but it is charging. we have a ipod 3rd generation mini.
hi ya,
Well firstly to use any Apple iPod products you need iTunes, which you can download form [http://www.apple.com/itunes/download/] for free if you don't already have it installed
once you have this installed, check this article form apple its great, will get you on the why to be a iPod guru ;)
http://www.apple.com/support/itunes/windows/tutorial/index.html
