My tv is plugged into the coaxial cable antenna but not subscribed to cable service and everything was fine for awhile. After the digital transition, my tv could only pick up 4 local broadcast channels and only sporadically. Otherwise, I would get the warning that the digital channel signal strength is low. I rescanned for channels and only picked up about 5 channels even though they still say signal is too low. I thought it was because I was using a splitter to my cable modem but I have since moved to a new apartment and still plugged into the coaxial cable antenna without cable service. I rescanned and only get 2 channels without any signal either. HELP?!
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
will not pick up digital on cable
