When I connect my iPad with my computer with the USB cord, I expect it to sync all music and photos. Nothing happens!
When you connect your ipad to computer Itunes must be recognized it .
Make sure itunes version 9.1 installed.
If not then download from this link click here
Make sure ipad is enough charged.Try different usb ports.Makes ure usb cable is working fine.
Uninstall usb drivers from computer then check.For that press windows key +R so you can see run type in run "devmgmt.msc" then press enter.
Then you can see device manger uninstall all usb drivers 1 by 1 then it automatic install usb drivers.
restart iPad, first turn iPad off by pressing and holding the
Sleep/Wake button until a red slider appears. Slide your finger across
the slider and iPad will turn off after a few moments.Next, turn iPad on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is
iPad not responding? To reset iPad, press and hold the Sleep/Wake
button and the Home button at the same time for at least 10 seconds,
Then check then you can sync it with itunes in computer.
Let me know if you need further assistance.
Thanks for using FixYa.
ITunes enables you to sync pictures between computer and iPad, and it makes the sync very easy to be done.
iTunes will transfer pictures from computer to iPad immediately. When the sync is done, you will be able to view the pictures on your iPad.
If the method mentioned above doesn't work, you can also take advantage of the cloud service app to sync pictures. Let's say, if you have Dropbox on both your computer and your iPad, you only need to put the pictures in the Dropbox folder on your computer, and then you will be able to view them on your iPad. This is also a very fast and conveniteent way to sync pictures from computer to iPad.
via How to Transfer Pictures from Computer to iPad Air 2
Solution was perfect! Clear and complete. Photos now synced with iPad. Thank you for quick response.
