Yes, I tried new batteries as well as the codes, however, neither one worked. I forgot to let you know that the codes for this Tivo remote is only four digit codes, not five.
If you go to Directv.com and go to the remote control programming section you can put in the make and model of the tv and it will usually come up with a specific code that may work. I hope this helps a little bit. :)
The RC64RB has more codes in it. Unfortunately, it is an extra $25. BUT, it is backlit, which is very cool at night. With my RC64RB, I get 16 codes to enter for your TV (Emerson HDTV).
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
