What does Code F3 mean
The F3 error code for a GE microwave means the control is sensing a stuck or shorted key. Try pushing every button multiple times and do it firmly.
Hold a blowdryer in the corner of the keypad then slowly move it down as you peel it back (but not off). Take a sponge with the tiniest bit of dish soap and run it over both the sticky part (back of the circuits) and the place it is stuck to. Blowdry this til touchably dry and then reapply the kaypad face. Wait about 10 minutes until you plug in again for it to cool off.
If that doens't work, UNPLUG the unit and try to gain access to the electronic control board. If you can there may be a ribbon cable you can unplug from the board and try wiping the end of the cable hard between your thumb and index finger then wipe with a paper towel and reinsert the ribbon cable. May work but more than likely you will need to replace the touchpad.
SOURCE: GE Sensor Microwave model JES1456wf001 error code
my ge microwave oven model HVM1540LMICS reads "LOCKED", how do I unlock?
SOURCE: GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
SOURCE: My ge microwave is showing a code of F3. model
hello there
Tthe f3 code is referring to a faulty touch pad which may need to be replaced i would contact the manufacture of this microwave for a parts replacement
SOURCE: GE Sensor Microwave model JES1456wf001 error code F3....how do we
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
