Question about Dell OptiPlex 330 Desktop Desktop Computer
Buzzing noise on boot up, about four buzzes. Monitor stays black, power light on machine stays on, and green, but nothing comes on the screen. Led on motherboard is orange.
  • 3 more comments
  • Anonymous Jun 08, 2010
    Okay its six long buzzes. They're not beeps, but a buzz coming from the motherboard area. None are shorter or longer than the others, just six in a row about half a second to a second each.
    Thanks for your help by the way. This is my work computer and I am currently dead in the water and we have no IT here so I'm kind of on my own.
    Oh an also the "1" and '3' stay lit in the front of the machine if that helps at all. All green lights no amber or red.
    Ok so I mightve found the problem. One of my memory sticks looked loose, so I took it out and the computer stopped having the problem when I rebooted it, displaying "amount of system memory has changed." Now is it possible my card is damaged or scrapped? Ill try putting it back in and see it it gives the same problem.
    Replaced the ram card much tighter this time, rebooted and the comp is fine. Thanks so much for tryin!!
    New Friend:
Mine's an OptiPlex 760, replacing the power supply Almost works. It posts for a second, then the fan revs up and the power light turns amber. No diagnostic lights, and I have also tried replacing the RAM, and CPU. Absolutely nothing. There are no bulged caps, anything I can do without going through Tech Support? :)
Posted on Apr 09, 2016
    Scholar:
  • 67 Answers
The first thing to check would be the CMOS to see if there is a setting for "case intrusion" or something to that effect. Some computers have sensor that goes off the computer's side panel is opened. I believe this can be disabled in the CMOS and/or it's just a wire connected to the motherboard that can be disconnected.
It could also be an important fan, like the CPU fan, isn't spinning fast enough which may or may not lead to an over-heated CPU.
Also check to be sure all the memory sticks are firmly seated.
If it doesn't look like any of those it could always the the power supply. See if you can borrow one for a little while for testing purposes just to see if it works.
If none of those pan out I would say call Dell support and see what they say.
Posted on Jun 08, 2010
6ya staff
SOURCE:
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
When the monitor is turned on the screen goes on but there is a buzzing noise coming from the power supply board, then after 3 seconds the monitor goes black but the green power light is still on and the...
Sounds like the common Bad Capacitor story! If your monitor is not under warranty and you have any soldering skills this is only a 10 dollar fix. There are dozens of tutorials on youtube that will walk you through this. Search "Monitor capacitor replacement".
Aug 05, 2011 | HP L1740 17" LCD Monitor
I have a 24in wide lcd monitor for my computer and
mcdevito75 here, The red power light usually means the monitor is off, if when you press the red button it turns to green, or blue then the red power button means the monitor was off. Your monitor could be burned out.
Jul 16, 2010 | Computers & Internet
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
My Screen might be out??
dear ...,
when switching on te laptop, does it make noises, does the fan run, the CD/DVD-drive
LED shows green light and the harddisk rattle little bit? - good for you if it does, as the system still boots up !
to check if the LCD screen is broke and not the graphics card malfunctioning:
hook it up to an external monitor (one usually used with desktop PCs)
when laptop is switched off, using the 3-pin input in the back or to the right side of your laptop, and make sure the external monitor's power cord is properly fused...
Now switch on the external monitor first and then your machine again, and wait for the laptop boot messages on the monitor!
see anything? if yes the laptop screen is broke and needs to be replaced.
If still the external monitor stays black the onboard graphics card is up in smoke and you're in big trouble then.
Good luck finding out!
Oct 22, 2008 | Toshiba Satellite M55-S135 Notebook
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
Dell OptiPlex 330 Desktop Desktop Computer  Logo
1,634 people viewed this question
Ekse
Clive
Clive
Alun Cox
