HP Photosmart C4280 Aio Printer Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
Mehandi Husain Suleman
Level 3:
  • HP Master 1,654 Answers
  • Posted on Jun 09, 2010
HP Master
Level 3:
Answers
1654
Questions
Helped
576270
Points
4530
Hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwareI am trying to scan a document and it is not - mag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Add Your Answer
    1helpful
    Trying to scan a document with an HP C4280 says USB cable not connected but it is
    USB cable may be bad, try a new one and see if it helps.
    These cables are normaly universal, check and see if you may have one from an old printer just laying around before buying a new one.
    Hope this helps@
    Regards,
    1helpful
    My printer will print but when I try to scan a document it tells me that the usb cord is not connected. The usb is connected to both the computer and printer. What do I do?
    try another printer cable , if same problem remove the program of printer and re- install it again, follow direction one by one, dont make a shortcut
    1helpful
    My HP all in one printer works fine, however when I scan - it says "USB Not Connected" My cord is fine, my driver is up-to-date... any ideas?
    the reason for this can be improper installation.. so try doing the installation again.. or run scan diagnostic utility that is available on hp.com
    HI, I have never used the scanner on my HP Photosmart C4280 all in one. I placed the document on the glass and pressed scan. The printer says the usb cord is not connected. I have one end plugged into the...
    Hi! I will be glad to assist you in this issue, here are the how to setup the scanner on your printer. here is the link:
    how to install the product:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01705280&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=1141647
    how to scan to the product:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01843437&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=1141647
    2helpful
    3answers
    HP Printer C4280 says "USB not connected"
    Install software that is twain compliant.
    Maybe the HP bundle that came with the printer.
    Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
    Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
    2answers
    HP Photosmart C4280 All-In-One Will Not Scan
    hi
    i had the exact same problem and i installed and un-installed
    over and over again
    and then it hit me !!!
    why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
    it's light, recognize the scanner (C4280) automatically and scan !!
    cheers
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
