Some older cameras will only accept certain size memory cards and types. Some faster new memory cards may not work with your canera - check your manual
An update for fellow readers.. After reading few other posts and googling a bit, I was sure that I've got non-authentic memory card.. I tried and inserted a new genuine memory card and all the problems seems to have vanished (for now :)).. I'll keep you posted if the problem appears again.. To find out if your sony memory card is genuine or not, read these guidelines from ebay..http://reviews.ebay.co.uk/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001535763
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
1. Turn off the camera. 2. Clean the gold contacts on the lens by
GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the
camera face pointing down, also clean the gold contacts on the camera,
being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
I would recheck all of my settings on the camera. Go to the menu and check everything one by one. Your card may be damaged also. Do you have another card to try? Do you have your manual? If not you can to to www.olympus.com to download a new manual specifically for your camera and it may address this issue. Good luck.
Had this problem before and i found this guide online
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
camera should be serviced.
Error 99 is a general fatal error. which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
If the new 512mb xD card has a prefix of "H" or "M" before the 512, it is not compatable with your A330 unless a firmware upgrade is performed on the camera. You can download all the details here http://www.fujifilm.ca/x3720.xml
