Tip & How-To about Panasonic DMR-EZ47V DVD Recorder/VCR
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down buttons at the same time until it says "Bye" on the display. When it shows the clock it is off - wait a few seconds then turn it back on - you should see the initial setup asking you to choose a language.
Note: You may have to flip down part of the front panel to reveal the channel buttons.
Press and hold CH Up and CH Down button on the main unit for about 5 seconds.
(Current channel line-up and television program list are cleared.)
Select "Yes" in "Restore Default Settings" in the SETUP menu.
This returns all values in the SETUP menus, except for the clock, channel settings, ratings
level, and on-screen language, to the default settings.
While the disc tray is open, press [DVD] then press and hold REC button and Play/ [PLAY/* 1.3] BUTTON on the main unit at the same time for 5 or more seconds
Press and hold POWER button on the main unit for 10 seconds. (The settings remain.)
OK.
