Question about D-Link DKVM-4K (dldkvm4k4port) KVM Switch
Problem connecting two PCs by DKVM-4K
I tried to connect one linux and one window pcs by kvm switch. single console was ok for both pcs BUT mouse and keyboard are not functioning on both pcs. Sometimes working on linux not on windows and vice-versa.
Meanwhile some error came into my linux system and it got bad. Anyhow recovered my data and i came to know that files are corrupted on /var dir. I am facing serious problem.
could any one help me out? pplz do
Mamoon
  • 3 Answers
You should always use 1 switch per pc as that's mostly recommended.
Posted on Jun 29, 2009
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 6 Answers
SOURCE: DKVM-8E KVM switches :: how do i reset the console password
password is 00000000
Posted on Aug 03, 2009
DKVM4K, no vga output
I don't know anything about that KVM but you might see if there is a reset button to reboot it. or if it has an external power supply unplug it and try resetting it that way.
Apr 01, 2017 | D-Link (DKVM4K) (dkvm-4k) 4-port KVM...
Kvm switch is not detecting my g5 mouse , tried diff ports and tried alternating keyboard and mouse. think the switch has gone bad
this is not uncommon. many kvm switches cannot work with those types of wireless mice. the reason for this is due to connection codes. these mice require a connection to secure the use with each computer. you can attempt to do this with your setpoint software. located in C:\Program Files\Logitech\SetPointP you will find the program CONNECT.EXE
run this to redo your mouse connection. i will however inform you that even if this works there is a large chance that upon switching to the next pc the mouse wont work and you will need to repeat this process with each pc switch everytime you toggle pcs.
rule of thumb. if the mouse is wireless don't use it with a kvm.
Jun 29, 2011 | IOGear GCS632U 2-port KVM Switch
How to connect 2 computers to a dlink 4 port kvm switch?
The unit comes with all the cables in order to connect up to four computers to one KVM switch. If you're only using two computers, then you'll only need to connect one computer to Computer 1, and the second computer to Computer 2. The KVM will recognize that only two devices are connected, and generally skip the inputs for computers 3 and 4 until they have a device connected.
Feb 26, 2011 | D-Link DKVM-4K (dldkvm4k4port) KVM Switch
Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Keyboard and mouse problem!
I've had this problem happen lots of times before. usually restarting the PC with the switch enabled to the PC that is booting will solve this problem. For some reason, sometimes the drivers don't load for the mouse and keyboard when starting up the PC.
Dec 16, 2006 | D-Link (DKVM4K) (dkvm-4k) 4-port KVM...
D-Link DKVM-4K (dldkvm4k4port) KVM Switch Logo
319 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
