How do I connect it to a motorola 2210 modem
This FAQ is for configuring a BellSouth supplied Motorola/Netopia
2210-02-1006 with a generic third-party router that isn't specifically
covered in the existing FAQs. If you have a router that is covered in
the FAQs, I suggest you use that FAQ. This initial setup is all that is
needed to configure and connect your generic router based network for
FastAccess DSL. Any additional setup for features like DHCP IP ranges,
port triggering, etc is out of the scope of this FAQ.
This
FAQ has 4 Major sections:
Section 1 - Overview
Section
2 - Motorola/Netopia 2210 modem configuration
Section 3 -
Third party router configuration information
Section 4 -
Connections and power up
•The
best configuration for networking a router with the Motorola 2210 is to
set the 2210 to "Bridged Ethernet" mode and allow the third-party
router to do the routing and DHCP functions. The 2210 is also a router
with full DHCP functions and may not function correctly when connected
directly to another router. Not changing the modem to Bridged Ethernet
will result in double NAT'ing, increased latency, possible IP conflicts,
or possibly a network that doesn't work at all.
• Before
proceeding both the 2210 modem and third-party router must be reset to
default. Despite what the help desk tech tells you, resetting the modem does not
put it into Bridged Mode.
• The BellSouth Installation CD
and Connection Manager are not required to use this configuration.
The third-party Installation Wizard CD should not be used in this
configuration.
• Since BellSouth assigns static IPs via your
username the configurations shown are applicable to both dynamic and
single static IP customers.
• You must connect the 2210 directly to
the computer's NIC to make the necessary changes before you connect the
router, because you will probably be unable to access the modem
interface after you connect the router. The reason is that the modem
interface is 192.168.1.254 which is a local IP. By default, most routers
do not have the capability to route a local IP out of their WAN port
(where the 2210 is connected). Additionally, they may be on completely
different subnets. After you have made the changes to the 2210 you can
then connect the router and configure it for use with FastAccess. There
are several alternatives around this problem. One method involves
extra equipment (second NIC and a hub) and major configuration changes.
The second method requires you to utilize the router as a simple switch
and use the 2210's PPPoE and DHCP functions. Click here for more
information.
•If you encounter any problems simply reset the 2210,
connect it directly to your NIC, restart your computer, log into the
interface, and start over again.
Section 2 ? Motorola 2210 Configuration
Step 1
Verify
that NIC cards (wireless or wired) are set to "Obtain IP Address
Automatically". Completely power down the 2210 and the computer(s).
Power up the modem and press the reset button on the back of the modem.
After the modem has fully initialized connect the 2210 to the NIC and
then power up the computer.
Step
Open a browser session and enter "192.168.1.254" in the
addreshow do I connect it to a motorola 2210 modem - bred.gifto access the 2210 GUI interface.
Step 3
Enter your BellSouth
Username followed by "@bellsouth.net" in the User ID field.
Enter your BellSouth Password in the Password field. Re-enter
your BellSouth Password in the Confirm Password field. Click on Next.
Update the Auto Calender Update Configuration as desired and
click how do I connect it to a motorola 2210 modem - bred.gif/b>. The modem will try to initiate a session and then
return to the main menu.
Step
Click on Broadband DSL Line from the top menu. Click on
Configure Connection from the right menu. Select "Bridged
Ethernet" from the Protocol pull down. Click on Save and
restart the connection at the bottom. This will automatically
restart the modem and the interface will return after the changes are
saved. Note: functions like NAT, DHCP, IP Passthrough, and username and
password will be disabled or irrelevant and can not be selected. After
the modem has restarthow do I connect it to a motorola 2210 modem - bred.gifr down both the computer and the modem
then physically disconnect the 2210.
Section 3 - Third-Party Router Information
Step 5
After the PC is
powered down connect one of the router LAN ports to the computer NIC and
power up the third-party router and then the computer.
Step 6
to access the router interface as per the router's user guide. Even
though the interface will vary from router to router you must use the
following configurations as a basic rule:
- Select Obtain an IP
address automatically. Important Note: Use Obtain an IP
address automatically even if you ordered a static IP.
- Select PPPoE
connectivity. Do not select any other choice, even if you have a static
IP.
- Enter your BellSouth Username followed by
"@bellsouth.net"
- Enter your BellSouth Password
Select "Keep Alive" or "Always On" (if available)
Set "Maximum Idle Time" to "0" which is similar to "keep alive"
and "always on" (if available)
- Select a redial or how do I connect it to a motorola 2210 modem - bred.gift period
of "180 Seconds" (if available)
- Enter "1492" in the
MTU Field (if available)
- Save your settings (which will probably
restart your router)
Section
4 - Connections and Power Up
Step 7
Power everything down
and physically connect the 2210, wired or wireless router, and any
Pictures
by Andy Houtz
Step 8
Power up the network
equipment in this order:
1) Motorola 2210 Modem (wait for DSL synch)
2)
Third-party Router
3) Computer(s)
Open a browser session and go
surfing!
Important
Additional Information
•The 2210 has an "Internet" light that is
green whenever thehow do I connect it to a motorola 2210 modem - bred.gif active PPPoE session initiated by the
Motorola. Since you are using the Netgear to establish the PPPoE
session the light will stay off. This is normal.
•You should check
your tweak settings
to optimize your new network. Reminder: If you are required to
change your MTU, make sure that it is identical on all equipment (PCs
and routers) in the network.
Cool Stuff
An online,
html-based menu simulator program is available here.
The simulator recreates the Motorola 2210 user interface and provides
the ability to navigate menus; just like the real modem interface. It
is for simulation purposes only and will not make any changes to your
actual modem.
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
One thing that isn't mentioned anywhere is the modem has to be in bridge mode. I was told this by a Linksys tech after doing all that was documented in the references article. I contacted my internet provider and they told me how to set the modem to bridge mode. This corrected the PPPoE error.
SOURCE: Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
SOURCE: BRIDGING MODEM AND ROUTER
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Click Here for more info
SOURCE: My new WRT160N Linksys
For AT&T default IP address for the Motorola modem is 192.168.1.254.
Default for the Linksys IP address is 192.168.1.1.
Have you changed either one? For them to work correctly they need to be in different subnets. An IP Address of 192.168.y.xx, where y is the subnet and a different number for each device, usually 0, 1, or 2.
If they are in the same subnet, change the modem's IP to 192.168.0.254 or 192.168.2.254. Once you do this you will need to use the new address to access the modem.
You should make sure the router's gateway is outside the DHCP rage of the modem.
