My phaser 6180 says replace the transfer unit. i can not find A replacement for it
SOURCE: Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
SOURCE: Transfer roller usage message on Phaser 7700. replaced..still wont print
I found the answer here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Resetting Transfer Roller Life
Note: If the main Menu does not appear on the front panel screen and only Replace Transfer Roller is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Transfer Roller life:
SOURCE: phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
SOURCE: I have a Tektronic Color
hi,
the paper jamming problem is generic to most printer models of this capability. one way to circumvent this is to use a multimedia-tray while printing.
the reason is probably the two springs that hold down a silver metal pressure
roller in the feeding unit. The tension is uneven due to old springs
and the paper pulls crooked. If you follow the paper path in the fedder
mechanism, you will see the roller I am referring to. The springs are
at either end of this bar.
If you are good mechanically, you can replace the springs yourself,
although they are a ***** to get back on (some disassembly required).
try this for details on doing it.
cheers
