This error
code
indicates a water supply problem.
Are both
the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and
cold water faucets are turned on. Completely open both faucets for
proper fill.
NOTE: Both hot and cold water must be connected to
the washer
and turned on; the washer will not properly operate with only one incoming
source of water.
Are the water inlet hoses
kinked?
Straighten the water inlet hoses.
Are
the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the
inlet valves are screens. Remove any accumulated film or particles from
the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for
details; find them by entering your model number inMy Whirlpool front load washer has an error code - fl_hot_cold_back_of_washer.jpg>
Is the water pressure less than 10 psi?
If the water pressure is too low, the washer
may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your
local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or
more than the manufacturer's recommended amount of detergent, can cause
excessive suds. The excess suds can prevent the washer from detecting
the incoming water.
Concentrated detergents labeled 2x and higher will require a smaMy Whirlpool front load washer has an error code - helogo.jpgt of detergent based on load size. Always follow the manufacturer's
recommendations.
See also:
Why HE
High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off
the water to the washer?
These hoses have a valve inside that will close if the water pressure
is higher than two gallons per minute; this will shut off the water to
the washer. If
one of these hoses becomes loose, the water flow through the hose will
increase and close the valve inside the hose, which will shut off water
to the washer to
prevent a possible leak or flood. If the hose is not loose, tMy Whirlpool front load washer has an error code - hcz_003_web_env1.gifs back to the store for a replacement set.
To remove the error
display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTES:
NOTE:The above article dircty from whirlpool customer help site.
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
