Try to reset the unit by pressing the Resume button and switch on the printer, release the Power button while still holding the resume button, then press the resume button twice and then release ... then press the Resume button four times... then press once the Power button... then switch off and on...
I have a Canon ip2600 that has experienced the waste ink absorber (nearly) full problem twice. Most solutions state pressing Resume 2 time then 4 times, etc. I found 1 EZ solution that works! Keep in mind the first thing is to get into the right side with long tweezers, & get those pad(s) clean. Now to reset the error message:
1. Power off
2. In middle of back panel, disconnect the power cord
3. At SAME TIME, Press & HOLD Power Button down while reconnecting the power cord
4. Now release the power button
5. Now press the power button again
Wait & See - it works !!
Wow! You are so right! That was way easy for the reset and beats the other method I had used on my last one to pieces! Thank you for sharing!
SOURCE: ink absorber full, ip2600
I have a ip2600 that has had the waste ink absorber msg come up twice. After trying several recommended fixes involving pressing the Resume key twice then 4 times, etc., I've found the perfect solution. Start by cleaning the waste pads with tweezers, etc.
1. Press Power Off
2. Disconnect Power Cord
3. At SAME TIME, Press & HOLD Power Key while re-connecting Power cord
4. Release the Power button
5. Press the power button again
This will work!
SOURCE: ink absorber is full
Use this tool
http://www.startcopy.ru/repair/files/ip1100.zip
!!! Don't forget to vote!!!!
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
SOURCE: E27 Waste ink absorber full
canon mm140 E27 = Waste ink absorber full or platen waste ink absorber full what would be made to solve this problem
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
