Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
I have a lens error on my canon powershot sd1300 isi was very careful with the camera. Is there any way to manually reset it so it works again
  • 1 more comment
  • kmmills
    kmmills Feb 18, 2012
    Thanks. It was the dirt, and the blowing helped. I'm glad I didn't throw it away and get a new one cause I really like my camera!!!!
  • kmmills
  • kmmills
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 10, 2010
  • chifladito Aug 30, 2011
    Thank you so much. I recharged the battery, and did step 7 and, voila!, it worked.
    Thanks for the tip.
  • Nspoke1 Jan 09, 2012
    Thank you I mean...hehe
    New Friend:
Posted on Feb 18, 2012
  • Nathan Rumley Apr 28, 2013
    You saved my vacation thanks man!!!!!
You saved me from a costly repair. Step 7 worked! Task you so much!
Posted on Jan 09, 2012
    New Friend:
I just had this happen on a SD1300 IS. The battery went dead and I had memory card error all while the lens was out. Put a charged battery in and try to start camera, lens would not retract and I got this error. After trying some of the above suggestions, I decided to take the back and front covers off the camera. I put the battery back in and turned it on and without the front cover interfering with the lens housing it was able to retract. Put it back together and it works now.
Remove screws, including one under USB connector cover, pull apart very carefully and slowly, back cover first. The front cover I probably worked on for 10 minutes but it finally come off without breaking anything.
As a side note I see there is a replacable BIOS battery in there so when the camera will no longer remember the date, that will be why.
Posted on Oct 01, 2019
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I tried all of the tricks - no success yet. will give a try again. anyhow very much thks for yr tips that reallly gave me courage to try things i woukd risk on my own. thks
Posted on Feb 23, 2016
    New Friend:
Thanks a lot for your help!!! I am so happy! Step 6 did the trick for me.
Posted on Jan 29, 2013
6ya staff
SOURCE:
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
Canon powershot lens error
Above are troubleshooting steps for this problem. And the following provides more details on these steps:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 24, 2013 | Canon PowerShot SD1300 IS IXUS 105...
Lens error for digital camera,lens error well shutdown automatically restart your camera
Oct 13, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a lens error on my canon powershot sd1300 and i have no warenty. how can i fix it myself???
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 26, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera says lens error and shuts down immediately. Lens won't close.
Sep 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Hello! I have a canon powershot S1300 IS and when I go to turn my camera on, it says Lens Error Will Shut Down automatically. restart camera. I don't know what to do...
Aug 03, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Lense error camera will shut down automatically reset camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
22,592 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
