MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE BUT IT STAYS BEHIND THE SHUTE DOOR AND DOES NOT LET IT OUT AND THE DOOR IS NOT STUCK
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Most likely the issue is in the door rotary damper (241689301) that actuates the dispenser door flap. You can remove your ice bin and with the door open (holding freezer light switch closed) hit the ice lever and watch to see if the door opens or not from the inside.
The rotary damper is up inside the dispenser housing and should connect to the actual lever you may have to disassemble the dispenser to see it.
