Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
PLEASE TELL ME DISPALY FIGER IS HALF CUT THEN THERE IS DISPLAY OR LCD PROBLEM YOU AVE TO REPLACE LCD DISPLAY U WILL GET IT FROM ME
