Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Posted on Jun 11, 2010
I want 2 run exfat pendrive in windows xp
I have kingston 40 gb pendrive its not working in windows xp but it runs in windows 7 it is exfat format when i open this pendrive is opened it says me to format but it cant format pls reply quick
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1126
Points
5
First, your Windows XP must be either SP2 or SP3, and then you must add a patch to it. http://support.microsoft.com/kb/955704/en-us that is KB955794 for the patch
1helpful
Kingston 2gb pendrive shows the drive but unable to open, format what to do
I have had this solution many times in the past, unfortunatly there is only one thing you can do...
This is assumeing you are running windows 7.
1. Open Command prompt by searching cmd in the start search aera. Right click on it and press "Run as administrator".
Type in the following - (Replace x with the drive letter that is indicated by windows.)
format x: /U
This will reformat the drive assumeing that there is no damage to the NOR chip and its command block.
2answers
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
MY 2 GB KINGSTON PEN DRIVE SHOW WRIGHT PROTECTED AND CANNOT DELETE OR FORMAT PLEASE SUGGEST THE WAY HOW I FORMAT MY PENDRIVE?
Try to format in other operating system like windows vista ,windows 7 but not in windows xp
I have a pendrive of kingston company.somehow it has become write protected...plz help me to resolve tis problem
your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
If the above method is not work
try to format in other operating system like vista or in 7
but not in xp because in vista and 7 you can force format your pendrive..
I got a 16 GB Kingston Pendrive, after connecting
Format it again but using FAT file system not NTFS
Ajay Marya
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
3helpful
2answers
40 GB Kingston Pendrive Showing 8 MB & unable to format it.
Format it using a format utility which you can download it from any free software sites, type in format utility.
67helpful
9answers
Unable to format 64 gb kingston pen drive
I am having 64 gb kingston pen drive.
But after formatting from command promt its file system is RAW an i cannot use the drive now.
Beacuse it is showing properties as 0 bytes.
The drive cannot be formatted.
4helpful
3answers
Driver for Pen drive Kingston 2 GB
Hi
u do ot require driver for xp. its plug and play
if its not working than something wrong with ur xp- usb configuration. pls checkp their
Kingston 256 usb pendrive to run in windows 98
i suggest you upgrade your windows to windows xp pro sp2
windows 98 is not plug and play or you may try this http://downloads.drivershq.com/DriverDetective/DriverFiles/DriverDetective.exe
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
