Expert
- Posted on Jun 12, 2010
Re: My unit is working properly; however it is leaking. ...
Try to blow into the drain line from outside to clear the line if you don't want to take apart the evaporator. Also check for level of evaporator. If this does not help you your unit could be low on charge and could be starting to freeze. More likely to be a drain problem. hope this helps you.
