My first answer would be to turn it off and back on. Doing that will free up short term memory on the device. If that fails you have a TF slot, which would support a micro SD card up to 32GB. I honestly think taking your device to a best buy would be a good idea, they can probably open the card and make sure it is compatible before you buy it. Just remember to tell them no larger than 32 GB. Good luck!
A TF card is a TransFlash card, an early Sandisk term for their micro-SD card. They are interchangeable, so just look for a micro-SD card of whatever size you want.
Sony Cybershot DSC W5 only supports Memory Stick and Memory Stick PRO. So, in order to use your micro SD card, you will need to insert your micro SD card to a memory stick adapter like this:
I hope this helped you. You can rate my answer if you appreciate my help.
A kind of memory card for some products as mobile, camera and so on, there are size kinds of SD card. Generally cameras using larger ones and mobile using smaller ones.
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
