Question about Vision Fitness T9550 Folding Treadmill
I have a vision fitness treadmill. I turn on the treadmill and it starts at P1 and then it automatically goes through all the programs and sppeds until it gets to 10 miph. I have tried unplugging it. I have tried touching every button. I can't figure out what happened to it. Any suggestions.
    President:
  • Vision Fitness Master
  • 832 Answers
It sound like either the function pad ( more likely the problem ) or the upper electronics have failed. You will need to call Vision Fitness customer support @ 1-800-335-4348
Posted on Jun 14, 2010
6ya staff
SOURCE:
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Dec 14, 2014 | Vision Fitness T9250 Simple Folding...
I am just asking a question. I dont want to sign up and I don't want to join Face book or google. All I want to now is do I have to use of the four programs that are listed on the top of treadmill
It is a possibility. I understand your frustration with treadmills. The P1 - P4 are programmed events. I am sure there is a way to make it just run after setting it to 3mph. Send me more information on the treadmill including name and model number...year if you know it.
Nov 13, 2017 | Triumph Academy Sports 400T Treadmill
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Oct 21, 2010 | Horizon Fitness T90 Treadmill
I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Jun 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Squeals on startup for about 1 minute then goes
Remove motor shroud and inspect the drive belt VF is imfamous for squealing drive belts better to call them and order a new belt here is their # 1-800-335 4348 Vision is now under there parent corp. name Johnson
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
My Vision Fitness t8500 treadmill's deck just stopped working. It makes no noise when i turn it on. all other functions (elevations & programs) work fine. any troubleshooting ideas?
I had the same problem. I even ordered a $300 controller board. The new board didn't work either. That's when I started checking voltages from the control board to the motor. That was good. Lastly I checked the brushes. Almost nothing left. . . The motor started working again after I put everything back together. I need to order new brushes and return that contoller board.
Dec 28, 2009 | Exercise & Fitness
Vision Fitness T9550 Folding Treadmill Logo
788 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Don Eagan
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
