Question about Miscellaneous
Tempur-pedic remote control does not work have put in fresh batteries - control lights up- but no bed movement Please advise Thank You Carol
  • 7 more comments
  • cat_one5055 Aug 18, 2008
    Remote control got wet. Batteries were changed and light comes on but will not work.
  • Anonymous Dec 11, 2008
    my remote for my Tempurpedic Deluxe swedish mattress does not work after I put in new batteries. It does light up, but that's all.
  • Anonymous Jan 29, 2009
    same problem
  • Anonymous Mar 02, 2009
    resetting the remote as suggested does not work in this situation. Mine is dead too.
  • Anonymous Mar 29, 2009
    my tempur-pedic remote also does not work after changing batteries & pressing the button on the power down box. the lights flash randomly on the remote but the buttons do not respond
  • bonyknees Apr 05, 2009
    Happened on March 30, 2009. My husbands remote and my remote went out at the same time, just a few min. apart. The power-down box under the beds are working or so it seems because the red light is lit-up. Tempurpedic walked us through the instructions over the phone but that didn't work. Two new remotes are on the way but until then, I have been sleeping in a recliner for the last 4-5 days. I wonder how much longer I can last.
  • Saundra Young
    Saundra Young Jan 13, 2013
    Guest
  • Anonymous Mar 30, 2014
    tempur pedic adjustable mattress will not lift up or down. I have reset it, and changed out the batteries in the remote. still nothing.
  • Laine Lee
    Laine Lee Aug 29, 2017
    I've become frustrated with warranty support for this product, because I'm unable to get consistent responses from the support representatives. Because I have two of these system, I've been able to precisely identify my problem by swapping parts between the systems. I have a bad control box (receiver, not remote), and now I'm simply interested in bypassing the wireless remote functionality and using a wired controller to manipulate the bed. Has anyone devised a method for doing that?
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Posted on May 18, 2009
  • 8 more comments
  • Maggie C Feb 23, 2012
    Thanks to Mike V of Antioch, CA once I took out the batteries from the power down box and left it unplugged for a minute the solution Susan suggested worked. My remote / box / motor all manufactured 12/2004 so the current manual did not help me. BTW the "OFF" button referred to by Susan in the vibration off button which is a circle with a line through it. There are no "OFF" labeled buttons on the old remotes. Maggie C, Ocala, FL
  • Bev S. Oct 29, 2012
    Same post as Maggie C's. Took me weeks to find this site since I lost the original instructions and mine too is as old as Maggie's with a remote looking and working like Maggie's. Followed Mike and Susan's instructions and now have bed working fine. Bev S. Minneapolis, MN
  • Bev S. Nov 17, 2013
    I've needed to reset the power box many times and up until 5 weeks ago the same procedures worked. Now I can't get it to work even though it looks like it's resetting properly.
  • guyyouknow Dec 03, 2013
    As I recall when speaking to a Leggett and Platt representative regarding the replacement of the motor assembly, I was informed that the electronic components of these adjustable beds are very sensitive to power spikes and surges that occur regularly in many households. One precaution to take with any piece of expensive electronic equipment in your home is to purchase an Outlet Surge Protector or better yet a Power/Line Conditioner with battery backup. Although line conditioners can themselves be very expensive, they will provide clean, regulated power to your most precious electronics. In most cases though, a simple surge protector is sufficient to prevent any damage to your electonic components. Get one and plug your bed into it. It CAN save your investment.
  • Debra Brunetti
    Debra Brunetti Nov 06, 2014
    I have tried all of these things and also use a power surge. My bed is still not moving at all. Very aggravatung as I need the various motions in order to sleep. I would greatly appreciate any help I could get in getting my bed to work. I have searched and searched and had no luck with any assistance. Very dissatisfied.
  • Brutus Simon
    Brutus Simon Sep 05, 2017
    My vibration is working but not the lift up and down I bought a floor model and have no warranty any ideas on what the problem could be?
  • James Harvey
    James Harvey Nov 22, 2017
    My remote stopped working. It will not light up even with new batteries correctly installed. It will take 5 weeks to get a replacement remote. Why is there not a simple direct control method on the motor under the bed??
  • Dewayne Gunter
    Dewayne Gunter Feb 22, 2019
    Try pressing the star button and the foot up and down positions all at the same time til the light blinks. Then see if it works.
  • Dewayne Gunter
  • msd msdian
    msd msdian Apr 25, 2019
    if you want to give ur feedback give it athttps://krogerfeedback.fyi/
Locate the power down box for the bed and press the "learn buton" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash solwly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY
Posted on Feb 13, 2009
  • 5 more comments
  • novella Sep 19, 2010
    thks it worked!!!
  • Torrance Newton Oct 29, 2011
    thank you Susan.....OMG ...it worked...oh nLord I have been with out my adjustable bed almost a year thinking i had to pay a lot of money to get this frame/ foundation fix...Lord bless you...
  • svflo1 Aug 28, 2013
    thank you, i was able to fix my elderly moms adj bed! awesome!!
  • Matt Drion Sep 01, 2013
    Where is the power down box located? Can I get to it without lifting up the mattress and flipping the base over?
  • Alicia Larson
    Alicia Larson Dec 13, 2015
    Thanks, I looked everywhere on the Internet for this particular model. You were the only one with answers! I'm going to find my instruction manual one of these days, as apparently I'm not going to find it online. Thanks again- You really saved me!
  • Lin Chamberlain
    Lin Chamberlain Mar 02, 2017
    I love you people...I knew you were here somewhere. Houston, Texas Lin...I had used your instructions many months ago..before I moved back from Conroe...and suddenly my bed would not work...yucky...I switched the bases this morning...and finally accidentally got one to work...but had to find and follow all the instructions and here at 1:20am I can finally go to sleep...with my bed raised JUST enough...thank you again.
    I am printing and filing this now.
  • Bobbie
    Bobbie Apr 30, 2017
    I've done everything that I have been told but still nothing. M ybed isnt even a year old yet. My bed is flat but it won't raise, vibrate or nothing. It is really frustrating. HELP!!!!!!!!!
    New Friend:
If you've had your bed for more than two years, and the fixes above don't work, your remote has probably gone bad. The company will be 'very happy' to replace it for about $60.00!! I've already had the motor replaced twice - once under warranty and once not. For $3,000 I should NEVER have to pay for anything for this bed. What junk!
Posted on Apr 19, 2010
    So, I should consider getting a replacement remote first? Are there local stores willing to loan me a working remote with a deposit to see IF that fixes the problem first? Anyone know?
  • Chaz Dale Dec 24, 2018
    I have replaced mine 4 times. 2 years is right, JUNK! Now they want 160+ for the remote. Anyone know of a universal RF learning remote that works.
    New Friend:
My Remote is from 2005. Here is what I had to do:Tempurpedic Remote Control reset instructions:The "learn" button also operates the power-down function of the power down box found under the bed. First, push the learn button for one second. Next, simultaneously push and hold down the "Position 1 Button" and the "Massage On/Off "(circle with the slash across it) buttons. The transmission indicator lamp on the remote will begin to flash slowly then very rapidly. After five-seconds elapses from the start of the rapid flashing sequence, release both buttons. The remote should now be synchronized with the adjustable bed and the adjustable bed operation restored.
Posted on Jan 28, 2013
  • 1 more comment
    Bill, our situation sounds the same. Were you able to locate the power down box easily? Our bed frame wraps all the way around and is quite heavy and also screwed together. I am hoping to be able to get to the power down box without taking everything apart. Where was it located on your bed?
  • Bill Nance Sep 02, 2013
    The power down box is the small box that's usually sitting on the floor. It should be very easy to get to. It has a small wire that runs up to the bed. It also has a backup battery in it. You should replace the battery once you find the box.
  • Ivette S. Jan 21, 2016
    Bill Nance
    Thank you so much! It was really helpful.
    Thanks to your instructions my remote fully works!!!!! God Bless you!
Http://www.lpadjustablebeds.com/includes/asp/open-file.asp?id=1700686251
Posted on Sep 08, 2011
    New Friend:
    Problem Solver:
  • 5 Answers
Well, that's just great, huh?! For the last week, we've been trying to get one of our remotes to work. We've already replaced the power down box ($40.00 not including shipping because I picked it up) because the batteries exploded and blew the battery compartment door off!! So, thanks for the heads-up. I guess I'll be calling to order a new remote. (I was told by L&P that the power down box had nothing "..at all to do with the operation of the bed.") ****!
Posted on Apr 24, 2010
  • golfstud Sep 01, 2010
    Susan's solution worked for me. Solution 2. Thanks.
Legget and Platt makes the adjustable bed base. Go to their web site http://www.lpadjustablebeds.com/adjustable-bed-base-manuals.asp. Look up the owner and remote control manuals appropriate for your bed, download and save for the future. Follow the instructions for reprogramming the remote control. If you have an old-school bed the ER-95MR remote control manual may be the one to use. The bed will have either a J-box on the bottom of the bed frame or a power-down box that contains two 9-volt batteries. Either box will have a push button (the "learn" button which also operates the power-down function of the power down box). First, push the learn button for one second. Next simultaneously push and hold down the "Flat Button" and the "Head Massage On/Off" buttons. The transmission indicator lamp on the remote will begin to flash slowly then very rapidly. After five-seconds elapses from the start of the rapid flashing sequence release both buttons. The remote should now be synchronized with the adjustable bed and the adjustable bed operation restored.
Posted on Aug 12, 2012
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Mostly all Android tools. We can enjoy premium TV channels totally free imobdroapp so you can watch it anytime while offline.
Posted on Oct 23, 2017
    New Friend:
Hei, I had the same problem a few weeks ago and it was very annoying. Luckily, I contacted one of the sponsors on the website Sponsors europarl co uk and they were really helpful. I recommend you try it too!
Posted on Nov 24, 2014
    New Friend:
    Welcome Back:
I bought that same product and had the same problem, in the end I returned it to the sponsors and they sent me a new one.
    New Friend:
I totally agree with you, these beds are great. Many of our Sponsors we work for make components for these beds. You can solve the remote problems with them.
Posted on Nov 20, 2014
    New Friend:
Check http://www.arisemobility.co.uk
Posted on Oct 11, 2014
    New Friend:
My friend who has 2 brand new superflex 2000 beds with a 4 way motor and a wried remote is selling them to me for a discounted price.The boxes are still sealed.After searching on the internet,many people have complained about the remote and motor not working.I would be very grateful is anyone who has used or is still using the superflex 2000 with a 4 way motor please share their experience with me.Also some other questions I have are:
1.The newers beds have a reset function on the plug itself,but the older ones especially the 4 way motor ones don't have a reset button.So my question is what does one do if the 4 way motor is stuck?How do you reset it.
2.How many times is a reset required?
3.Also some dealers said that the 4 way motor is not successful on the superflex 2000 and has had alot of issues with it?Is this true?Any real life experience would be extremely useful.
Thanks!
Posted on Jan 12, 2012
6ya staff
SOURCE:
Tempur pedic bed remote control
Oh yes we are, but sometimes it takes a few minutes! You posted to the category 'Cars and Trucks', which doesn't help.
$100 direct from the company.
Tempur Pedic Products Accessories
Jul 13, 2018 | Cars & Trucks
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
What is the difference between Tempur-pedic mattresses and other brands of memory foam mattresses?
Tempur-pedic is a type of memory foam. They are a brand name distributer of memory foam products. They have reached a level of popularity now, which consumers refer to their product as a brand (similar to Kleenex).
Jul 25, 2012 | Furniture
WIRELESS REMOTE CONTROL - MODEL - r2t3/r2t4. Wonder if you can help please! Have an Electric Adjustable Bed with a remote which has stopped working. Details on the back of the remote are - Model No:R2-T3....
I have a remote for adjustable bed that won't work. I know it is the remote, because I put a new 9V battery in and the red light doesn't come on. Model No:R2-T3. FCC ID: MGB _R2-T (03-680252-03). I see someone posted the same problem and don't see any recommendation to fix or replace it.
Jan 05, 2011 | Televison & Video
Miscellaneous Logo
82,202 people viewed this question
Top Miscellaneous Experts
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Philippe Dekyvere
Are you a Miscellaneous Expert? Answer questions, earn points and help others
