Question about LG 42LC2D 42 in. LCD HDTV
TV went blank. Sound is still there, but the picture is not showing. The light normally is green shows white. a few second the light is flushing.
  • 11,361 Answers
You either have failed 24vdc power supply section or failed backlight inverter board, look for 24vdc first on the power supply module.
http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LC2D+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 13, 2010
  • LG Master
  • 8,457 Answers
Ur tv have sound and than a total white color blank on screen for few sec.than dies?Yes,than is not the LCD inverter or the power supply board problems.It the Main Tuner board,that the board where the coalax incomming broscast signal plug into it.That the board it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jun 17, 2010
6ya staff
SOURCE:
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
Can dust build up on a picture tube's circuit board cause them to overheat and shut the tv down.
dust will not cause an issue like this in this type of set--RCA? it means a short of some type exists and the set shuts down or blanks the tubes--all you have described as far as appearance is normal.
RCA sets like this can be difficult to repair and also if you Google the model number you will see they have a lot of "problems".
Apr 23, 2012 | Televison & Video
The screen went blank and green light started flashing. Turned off the TV and let it cool. Turned it back on, getting sound but no picture. Red light is on, after about 15 seconds the green light blinks...
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Feb 25, 2011 | Toshiba 52HM95 52" HDTV Projection...
Sony Bravia - no picture, no sound. Just a blank screen. We were watching a show and the screen went blank and no sound.
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Dec 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
LG 42LC2D 42 in. LCD HDTV Logo
525 people viewed this question
Ekse
RONALD CARTER JR
