hi lea, does this dots and lines appears occasionally or it just stays there? because if its permanently there, then you might need to replace the lcd part of the lower screen (not the touch screen part) but if its occasionally, then try to see if it happens when your on the lowest brightness or highest brightness, if it is then you will have to adjust the variable resistor on the motherboard of the DS,let me know if you have to do this.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
These "black dots" you talk abotu could be a variety of things and since you haven't given much detail it's hard for me to say.
Just double check it's not your TV or cables or any nearby electrical products causing interferance so you're certain the problem originates from your Xbox 360.
Hopefully, it's just a problem with your cable, maybe it's not plugged in right or maybe a replacement will fix it.
When I say hopefully, I mean, hopefully it's a cable fault as opposed to an Xbox 360 hardware fault. Variations of black lines or dots, or just general artifacts on screen while using your 360 usually happens prior to a hardware fault usualy concerning the GPU.
I guess it's just a waiting game for you now mate.
Just check it's not your TV or cables or any nearby electrical products causing interferance.
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
Hi i on u r screen white dotted vertical lines comming & if the no. is more than 6 the if the laptop is under warrenty then company will replace the LCD & if not under warrenty then to fix this issue u have to replace the LCD.
Sounds like you may have "hit the problem" But to me sounds like the chip itself is no good anymore. Any chance of getting a chip off another board and replacing it?
