Hello there. I have a Samsung SV-5000W VCR, and I am currently having an audio related problem. When I play a tape recorded in SLP with Hi-Fi audio, the audio on the right channel constantly buzzes. Even when I adjust the tracking, that buzzing is still there. And when I play a PAL tape with Hi-Fi audio, often times I get buzzing sound on both channels. How can I fix this?
The hi-fi sound goes first. There is nothing you can do about it. Unless some special recording techniques were used, you always have a linear sound track too. Try to adjust TRACKING on the remote to hook up to the hi-fi track.
What is the recording speed of your tapes and DVD? SP SLP, etc. on tape SP SLP XP on DVD? That will determine the length of th recorded tape and the recording time the DVD can hold.
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking
would bring in the audio, but sometimes the video would get fuzzy. Get
the picture right and the audio goes out. Switch to Linear (mono on
some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
I bought mine yesterday and am having the same issues. No solution listed in the user manual to fix this and I have a rather extensive VHS tape library that I was hoping to move to DVD using this unit. Unable to watch any VHS tapes taped on my Panasonic VCR and it seems as if the tape is slipping. Tracking buttons don't fix anything. I found a blank spot at the end of the tape and taped something and it comes out fine. Could this have something to do with it being a 6 head VCR? Tapes are in SLP mode.
Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions.
You are quite correct "Plays NTSC tapes to NTSC,
Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom.
Hope this be of some help to you. Good luck and kind regards.
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes.
The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and
other kinds of damage.
