Hi,please follow the steps given below;
1.Install on your computer the software that came with your digital camera
2.Connect your camera to your computer using the USB cable that came with your camera. You must have a USB port to download pictures to your computer.
3.Choose the folder where you want your pictures downloaded. The computer will choose the "My Pictures" folder by default unless you want them in a different folder.
4.Preview the pictures. You can delete any you don't like or want. Make sure to delete them off your camera as well or the next time you download that picture will downloaded again.
5.Select a picture and print. Some software will let you put borders and cute sayings on your pictures. Have fun with it.
Take care
SOURCE: computer won't read card through usb cable or card reader
Try using a separate card reader to download your pictures to a folder you create on your desktop.
SOURCE: Cannot download pictures to computer
check your device manager on the computer to see if your if your usb driver are loaded and have no conflicts, u could also have a bad cable don't load the camera software on to the computer if you did uninstall the software from the PC and then plug the camera in and let windows recognize the camera if this does not work change the cable your using, GOOD LUCK
SOURCE: I cannot load images from the camera to the
Go get a card reader and transfer your images thru that. That's the only way I ever transfer my images from camera to computer. You can get one relatively inexpensive...that is...if your computer doesn't already have a card slot in it.
SOURCE: for some reason now my computer wont recognise my
Windows updates changes the registry and sometimes causes our "toys" to stop working. You can contact Microsoft and get instructions to re-write your registry(very dangerous if you don't know what you're doing) or, you can do what the pros do to avoid this very common problem....get a card reader!
