Question about Mx Black Max 24v Cordless 1/2 Inch Drill / Driver
My new Blackmax drill battery charger does not put out enough voltage to charge the 24 volt battery. I have only used the drill one time and have lost the purchase receipt. Where can I get the charger repaired.
  • 8,197 Answers
You can find a repair center on the link below. You just need to put your zip code in to find the nearest one to you.
http://www.blackmaxtools.com/customer_service/service_center_locator
Good Luck
Posted on Jun 13, 2010
Anonymous
SOURCE:
Can I use regular charger on 18 volt batt
* Like a 12VDC auto (car battery) charger? No. It does not have enough voltage to overcome the initial surge (about 20-22 volts)
* If this is a Lithium Ion pack the it should be putting out a minimum of 16 Volts DC to a maximum of 21 Volt DC.
* The battery (or charger) also needs to monitor the temperature of the batteries, Charge voltage, and Charge rate. This is to prevent over charging and over heating.
* Just slapping a charger on any multiple cell battery pack will destroy it if it's overcharged (over heated).
* If you do have a charger but the charger won't recognize the battery then it may be possible to give it a "boost" with another full charged battery (has to be the same type). This is where you connect the batteries in parallel (Positive to positive, negative to negative.) Let it charge for a short time 15-20 seconds should do it. Try the charger again.
* 18V Battery restoral (with variable power supply); https://www.youtube.com/watch?v=4Gj4yFX58UU
* Using existing charger to fix battery (does not always work); https://www.youtube.com/watch?v=6GfPKg05ZIU
* If your using NiCad batteries then you will have to "Zap" the battery (This is a bit hazardous); https://www.youtube.com/watch?v=5B9rx7hoizk
* I think the earlier video guy had the right idea. Just turn in the bad ones and get new on (or at least Lithium Ion batteries)
Aloha, ukeboy57
Jul 03, 2018 | Drills
I have a fully charged 24 volt Firestorm battery, that when connected to my drill barely turns it? What is wrong?
Do you also have a good battery that runs the drill well to proof the drill is good, and a volt meter (multi meter)?
I have several cordless tool batteries that show the rated voltage on a meter, and register as fully charged when on the charger, that no longer have any current capacity. They will barely turn the drill and die in seconds. This is a different problem than when freshly charged run fine but lose their charge in a few days or so. That is caused by internal short circuits in some or all the cells from "dendrites", a build-up of small amounts of the cell plates as little branches growing on the plates until they reach the other plate, causing a tiny short circuit. Dendrites can sometimes can be burned off, the way I do it can be extremely dangerous and I do not recommend it. I do it by putting 4 battery chargers in series, giving me an open circuit voltage of 59 volts. I for a no more than 4 seconds connect them to the battery - to - and + to +, with a current in excess of 50 amps. The battery gets hot and could explode, so I do it by reaching around a 1/2" thick poly-carbonate shield. Lacking a shield, i use a power strip to plug the chargers in Have the power strip unplugged from the outlet or extension cord, connect the charger clips to the battery, and from a distance, plug in the power strip just for 2-3 seconds. The battery may be quite hot. I then check the battery voltage, it is usually a bit higher than the voltage rating. I put the battery in the drill and if it makes a few turns, i run it till the drill stops, then charge the battery normally. I use 2 small 12 v chargers that have a 50 amp jump-start setting and two that have a 10 amp rating.
The proper repair is to replace or rebuild them.
Sep 04, 2017 | Drills
18 volt charger will not charge cordles colman drill
Could be the charger, or the batteries are defect. Sometimes just the contacts are dirty or oxidised. Make sure they are clean.
When you have a multimeter, you can check in the charger, if it is giving a voltage high enough to charge the battery and on the battery you can check its voltage is high enough to power the drill.
Apr 19, 2015 | Drills
Can you use 18 volt charger for 20 volt battery
No. It will not charge
to get batteries to charge the voltage in has to be greater than the battery voltage so the charger you want is 20 volts which in fact will probably be charging at 22 volts
Apr 12, 2015 | Drills
I have craftsmen 19.2 volt tools while using the electric sander my batteries have died and when i put them in the charger the green indicator light comes on saying they are fully charged , when in reality...
It sounds like your charger is faulty. Try to measure the voltage of the batteries. If the nominal (workingh voltage of the batteries are 19,2 volt, then they should invrease to about 22 volt while in the charger. If the voltage does shoot up when the charger is on, maybe even to 25 volts, (which should turn the green light on) the new battries are dead!
It happens!
The other possibility is that the batteries are OK & fully charged!
But!
Your sander is damaged. Again, try & measure the voltage in the sander, before & after you switch it on. A large drpop in voltasge can indicate the sander drawing too much current. Also try them in another machine if you can.
Andy
Sep 03, 2011 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Have a 15.6v cordless drill - both batteries charge up to ~6v and no more; the red led is on - are both batteries the problem? this is the second charger - drill does not get used very ofter - model of...
See if you can put a volt meter on the metal contacks of the charger to see what voltage it is producing. If you have a friend who has the same drill have him try to charge your batteries and then measure the battery voltage.
Mar 14, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE WITH OUT LOAD IS 51 VOLT.AND WITH LOAD IS 15 VOLT.THE BAATERIES BECOME VERY HOT WHILE CHARGING
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
May 18, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Mx Black Max 24v Cordless 1/2 Inch Drill / Driver Logo
640 people viewed this question
Top Mx Drills Experts
jcoberley
Level 1 Expert
ray gallant
Charles Tidwell
Are you a Mx Drill Expert? Answer questions, earn points and help others
