Beautiful watch. Very classy. Easy to adjust band with two links that can be removed from the bracket. Large round face with easy to read dial. The bracket construction is especially unique with the two different types of finish. GUESS Women Stainless Steel Leather Casual Watch Color Red Model U0627L5
To remove some links: If you don't have special tool, at least you have to have something really hard and thin (like the pin you use to post notes on the cork board). Put that pin in to the tiny hole between links where the bracelet pin is and then press/push it forward (follow arrow direction as shown on the inside of the bracelet links.) When the bracelet pin comes out at one end, pull it out of that end totally. After removing one links, connect the two links next to each other by placing the bracelet pin back into the hole and push it to the other end. To add some links: You have to have spare links and do the same way with the pin to attach more links.
It isn't a fault and can be adjusted. Follow this link and find out how to....
http://www.invictawatch.com/
Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"] To start/stop this, use the top button (Button "A"). To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A". The "second" hand is the small dial at the 9 O'clock position. In actuality, you 'could' start this and just not stop it... Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
To set the sweep arm pull the stem and crown out to the first or second
set position then press and hold down the start button. The sweep arm
will move into position and you can let go of the button when it is
where you want it.
