We too have the problem with the oven display. We got the kit and replaced both the display and the relay board. You are right, if the oven is not pulled out it is really tough to change the relay board. But I was able to change the relay board without pulling the oven out. I believe I put everything back together. The parts in the kit look exactly like the old parts. But when I turn the power back on, the display shows -F7-, an annoying beeping noise is heard, the fan and the oven light are on, and the glass control panel doesn't work at all. I did turn the power off for about 20 minutes and turned it back on again with the same results. Any suggestions??
Usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
Where were you able to get the panel display part?
