Frigidaire 22.6 Cu. Ft. Counter Depth Side-by-Side Refrigerator - Stainless-Steel Logo
Posted on Jun 14, 2010
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1223
Points
5
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Ice build up bottom of the freezer
You do not have enough air flow. make sure you do not block the vents inside the freezer and also around the outside of the freezer. It needs to extract the heat from inside to keep it cold. If you have no air flow, in and out, ice will build up.
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Hi i have a servis fridge freezer, the freezer is fine but the fridge does not get cold, any suggestions?
Try clearing everything away from the bottom venting in the freezer and check for ice build up in the vents. Defrost it like you would in the "good old days" and to ensure it doesn't happen again, keep a 1" to 2" clearance in front of the vents in the freezer. If need be, set a cookie cooling rack on it's side to act as a barrier for the vents to ensure proper air flow.
3helpful
2answers
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
1helpful
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 • Dishwashers
3answers
Not keeping food cold and popping noise
There is ice buildup in an area that you cannot see.
The interior wall may "bulge" a little if the ice builds up a lot.
1. You may have the cooling dial set too high (use lower numbers)
2. The blower vent into the fridge or freezer maybe blocked (move items away from vents inside)
3. Defrost the fridge. The water pan underneath the refrigerator may overflow.
If there is no "defrost" setting, unplug for an hour (don't open refrigerator or freezer during defrost)
Plug back in, food will not spoil.
1helpful
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
6helpful
2answers
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
