Logitech QuickCam Messenger Web Camera Logo
A
Anonymous Posted on Jun 14, 2010
Logitech Quickcam V11.8 recently crashed my Window xp blue screen and had to reinstall the Windows xp. Now I use the same camera by plugging into the usb port and it runs better.. (note I didn't even install the driver and run the disk). But after a few use in one incident the blue screen appeared again and restarted my window. I suspect it is the Logitech Webcam that caused the crash last time which I wasn't sure what actually caused it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
305
Points
All drivers webcam : with "Cam-Drivers" download link: http://www.filefront.com/16785445/Cam-Drivers.exe
Khurram Shah
Level 3:
  • Logitech Master 10,322 Answers
  • Posted on Feb 03, 2014
Khurram Shah
Logitech Master
Level 3:
Answers
10322
Questions
0
Helped
1467348
Points
20232
1st You download Webcam Driver.
Logitech Quickcam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Logitech Camera Drivers for Windows XP Vista Windows 7
1 Related Answer
Anonymous
  • 8637 Answers
  • Posted on Jan 14, 2009
SOURCE: My Logitech QuickCam 5000 is crashing my computer
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
I have a Logitech Quickcam Orbit AF which causes my computer to crash whenever I try to use video. My os is windows 7 ultimate. Any ideas? DHA
It is most likely the driver for your camera. Check the Logitech website for the most up-to-date drivers and install them.
The crash screen, otherwise known as the "Blue Screen Of Death" or BSOD, is usually caused by an error on the driver level. This can happen when code in the driver for the device conflicts with something in Windows or your computer hardware, and the system shuts down to prevent damage. The BSOD gives information about what conflict occurs, and creates a "dump" file with more detailed information.
There is a freeware utility you can download here that will analyze the dump and give you more information about what caused it.
1helpful
My web cam is not detected
You may need to perform a clean install of the Logitech camera software if it didn't install properly or a another program in memory is conflicting with it. Removing the camera software and reinstalling it using a clean boot procedure may resolve the symptoms you are experiencing.
The following instructions will walk you through this process:
Remove the Logitech camera software.
  1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
  2. Open the Windows Control Panel.
  3. Open the Add / Remove Programs window.
  4. Locate the listing for the Logitech camera software and remove it. When prompted to remove the camera drivers files, click Yes.
Prepare the system for installation of the Logitech camera software.
    1. Go to the Logitech Downloads Page and select your product to download the correct version of the Logitech camera software.
    2. Please see here for the clean boot procedures.
    3. Doubleclick the icon for the Logitech camera software download file.
    4. Follow the on-screen prompts to complete the installation.
  1. Return Windows to its normal state.
    1. Use the instructions located here to enter MS Configuration window.
    2. Place checkmarks in the items that you previously removed them from.
    3. Click OK and allow the computer to reboot.
    4. Test the Logitech camera software to ensure your original issue has been resolved.
    Please ensure that you are using QuickCam 11.8 if you have Windows Vista or Windows XP
4helpful
Webcam compatible for MAC OSX 10.4.11
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
Logitech Quickcam install on a Mac OS X or mac laptop
Check here for MAC compatible cameras and under that is info to download your driver.
A. Skype Setup:
B. Yahoo Setup:
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Webcam causing windows to shut down
I think this a problem with a USB driver. I had a similar problem once with a USB mouse and keyboard, when running XP. I never isolated the reasons for it happening, but I uninstalled the USB drivers for both and reinstalled them and rebooted and the problem disappeared.
Maybe try uninstalling the Logitech driver and then doing a Registry Clean (and a Clean System) with nCleaner and then downloading the latest zipfile for your webcam model from the Logitech support webpage.
Then plug the webcam in. It will detect and try to look for drivers but not be able to find any.
Now unzip the driver to a folder. Go to Control panel > System > Device Manager, and look for the Unknown Device with a yellow exclamation mark next to it. Double click it to open the driver window and then click the Driver tab. Press Install Driver and choose the 'Browse Computer for Driver' type option and navigate to the folder you unzipped the driver to, select it and open it.
It will Install and then you should reboot.
The problem should be solved, unless some IRQ conflict still happens, in which case you should do a Scan for Errors with an operating system disk.
SO, to sum up, when in doubt, uninstall the driver, clean the registry,reinstall the latest driver, reboot!
Hope that helps
Chris (ziraffa)
3answers
Problem installing
During the upgrade installation to QuickCam 11.5 the installer will hault and display error code 2738.
Solution
Windows XP user:
  1. Please visit the Microsoft website and download Window Scrip 5.6.
  2. After installing Windows Scrip 5.6, please reinstall QuickCam11.5.
Windows Vista Users:
  1. Click on Start Button
  2. Click on All Programs
  3. Click on Accessories
  4. Right click on the Command Prompt, select "run as administrator"
  5. At the prompt type "regsvr32 vbscript.dll"
  6. You will now get a message box saying "vbscript.dll" has been registered
  7. Reinstall QuickCam 11.5
This resolve the problem.
Sergio
Driver Conflict ?
Download the version 11 software from this link.
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
